cps bolt - Diesel Forum - TheDieselStop.com
post #1 of 5 (permalink) Old 02-07-2007, 10:50 PM Thread Starter
cps bolt
someone help!, Is the 10mm bolt for the cps usually pretty snug? This is the original one and I don't want to break it getting it out, I've soaked it with pb blaster, it's not left hand threads is it?-thanks
purchased new this 1996 powerstroke 4 door dually 5 speed "272k" zf-5 speed
luk smf clutch kit,open air element, dppi 3" downpipe
wifes truck 2000 ford f150 ext. cab 4x4 5.4l 72k
ford 1900 tractor 3 cyl. diesel
1995 sooner dynasty horse trailer 4 horse w/ living quarters
john deere model l manure spreader in near pristine condition
williejrdp is offline
post #2 of 5 (permalink) Old 02-07-2007, 10:53 PM
STurbo90's Avatar
My Photos: (9)
Re: cps bolt
sometimes they can be a pain, make sure you use a quality 6 point socket. Its regular thread, by the way.
PSD,CC,LB,E4OD,4WDw4:10LS
STurbo90 is offline
post #3 of 5 (permalink) Old 02-07-2007, 11:03 PM Thread Starter
Re: cps bolt
I've got a good 6 point I'll just have to try it after the pb blaster soaks all night, I'm replacing the water pump so I felt it was a good time to change it out.thanks
post #4 of 5 (permalink) Old 02-07-2007, 11:33 PM
Re: cps bolt
A touch of anti seize before you reinstall is a real good idea. Do you have access to any Kroil, it's from Kano labs and is a fantastic product for loosening frozen/rusted nuts/bolts etc.
2002 F350 7.3 SRW Lariat ext. cab, 6 spd, 4X4 long box, Banks 6 gun tuner, 4 inch monster exhaust, Stancor GPR, Rancho 9000's, Zoo Dad, Dieselsite boots, Rhino spray on liner, 203 thermostat, South Bend clutch, Bellowed up pipes, coolant filter, AFE, CCV mod, 19.5 Rickson wheels with 245/70/19.5 Michelins, Power slot rotors and Hawk pads, Mag-Hytec differential cover, Sirius radio, Pillar gauge, Fumoto valve.
sixspeeddroner is offline
post #5 of 5 (permalink) Old 02-08-2007, 03:21 PM
PSDfreak's Avatar
Re: cps bolt
Just keep at it and be careful...mine was the same way...EXTREMELY tough to get off the first time.
-Casey
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
