cracked block or freeze plug - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 11-16-2008, 08:55 PM Thread Starter
kaquinn's Avatar
My Photos: (15)
I just bought another 97 tonight! it would appear that anti-freeze is leaking from the starter area anyone have an idea? is there a freeze plug there? maybe next weekend i can get a better look just thought i would through it out there see what you all had to offer!
OBSession
  • 03' F550 4x4 6.0 CC Lariat utility body:MBPR,BD EGR bye bye,afe stg2 dry, superchip cortex
  • 97' F-250HD 4x4 7.3 CC,SB: AFE stage II, MBRP-ss 4", BD-brake, DP-tunner chip,big oil, mostlysun coast trans, auto meter C2 gauges overhead, fuel?....
  • 97' F-250HD 4x4 7.3 EC,SB 5 speed
  • 96' F-250 Centurion 4dr bronco 4x4 7.3
  • 96' F-350 4x4 7.3 SC, LB
  • 95' F-350 4x4 7.5 460 CC,LB
  • 94' F350 4x4 7.3 N/A under cont./ referb.
  • 94' F350 4x4 7.3 turbo, dually auto
  • 86' F350 4x4 6.9 4spd dually dump
  • 85' F350 4x4 6.9 w/banks sidewinder
  • 85' F350 2wd 6.9
  • 06' Mercury Mountineer
  • 05'Explorer XLT 4.6 V8
  • 93'&(2)94'Taurus SHO 3.0 5-speed
TRUCKS ARE BEAUTIFUL!
kaquinn is offline
post #2 of 8 (permalink) Old 11-16-2008, 10:12 PM
Patrick Feeley's Avatar
My Photos: (19)
One of the block drains in right behind/above the starter. You might look at it. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #3 of 8 (permalink) Old 11-17-2008, 08:14 PM Thread Starter
kaquinn's Avatar
My Photos: (15)
drain? not like a pet**** but a freeze plug? well thats good news!
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
post #4 of 8 (permalink) Old 11-17-2008, 11:44 PM
My Photos: (19)
It'll be an NPT plug that can be removed to drain the block (1 on each side of the motor). Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #5 of 8 (permalink) Old 11-18-2008, 08:50 PM Thread Starter
kaquinn's Avatar
My Photos: (15)
well ive got my fingers crossed! thanks maybee i can check it out the weekend!
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
post #6 of 8 (permalink) Old 12-09-2008, 01:52 AM
cracked block or freeze plug?
I have the exact same problem on my 7.3. Did you ever find the cause or anyone with some advise. I have the same symptoms. Thank you brice
97F-350 is offline
post #7 of 8 (permalink) Old 01-01-2009, 09:54 PM Thread Starter
kaquinn's Avatar
My Photos: (15)
I wont be checking in to my problem until spring probably due to the work i am doing to my Crew cab! When i do find out i will let you know and hope you will do the same for me! good luck
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
post #8 of 8 (permalink) Old 08-24-2009, 04:34 PM Thread Starter
kaquinn's Avatar
My Photos: (15)
The leak was a freeze plug someone repaired with a rubber on that was in backwards! fixed that but still have a hair line crack! added some stuff to the anti-freeze and it hasent leaked yet! im happy 97 PSD w/5speed $1,500!
OBSession
  • 85' F350 2wd 6.9
kaquinn is offline
