Dana 50 Front Wheel Bearings - Diesel Forum - TheDieselStop.com
Old 10-30-2009, 07:05 PM   #1 (permalink)
Window&Door's Avatar
Ok, going to replace wheel bearings tomorrow...
Timken Part No. # numbers:
387A inner bearing (2)
382A inner race (2)
Set 38 outer brg w/race (2)
Hub seal (2)
I see two more part numbers: LM104911 and LM104949
Don't know what they are, done with google...
could these be spindle bearings?
I was wondering what else I should be servicing at the time, my U joints and ball joints seem to be OK, I keep hubs unlocked and drive around in 4x once a week or two to keep things moving. Should U joints and ball joints be replaced as preventative maint. at this point?
I plan on using Lucas Red N' Tacky to pack the new ones, any opinions on that grease?
If I get brave or ambitious I'd like to tackle my TTB pivot bushings, shackle and spring bushings and some tie rod ends among getting my wavy rotors turned.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 10-30-2009, 07:24 PM   #2 (permalink)
To add to the list, I may as well do ball joints too and forget about the front of the truck for ten years.
Driving on the street in 4hi with hubs unlocked, I hear a lot of noise, just assumed it was normal. Sounds sort of like clutch fan is hanging on all the time, is this normal U joint and spindle bearing bahavior?
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
