DB Starter Dead or ? - Diesel Forum - TheDieselStop.com
Old 11-19-2009, 11:52 PM   #1 (permalink)
About 3 weeks ago I bought a DB electrical HT starter installed it and it's been good.Until today!just click So I took it to the local O'riely's checker auto to have it tested they didn't have the right part # to put in there computer,but it said Pass!the pinion poped out but it did not spin!Any body have any ideas good or bad?starter relay?Thanks
Greger96OBS is offline
Old 11-20-2009, 03:19 AM   #2 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
No spin=No good. That is unless the person who tested it was clueless but you can test a ford starter with jumper cables. Hook one side to the battery and hook the negative on the other end to the starter housing and then while holding the starter dwon either with your foot or in a vice touch the positive clamp to the stud on the starter. If the pinion comes out but no spin it is a dud starter. If it comes out and the starter spins then they didn't test it right. It is entirely possible that you just got a faulty starter. That stuff happens from time to time.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
