Dead GPs Burnt UVCH - Have Valve covers off should I change anything else???
I have been having problems (major problems) starting my PSD when cold if not plugged in. It's a Van and it's been a Pain in the Rear to get those valve covers off. I got it. I ended up slitting and bending the metal around the doghouse lip near the valve cover on the Passenger side and got some little 1/4 drive ratchets to get the bolts loose. Anyways, so far so good. I can now see everything. Good feeling to say the least.
ANYWAYS, enough of that, no victory yet. I still need to fix this thing.
Ok, so here's my list let me know if I should add anything:
-Glow Plugs.
-UVCH is burnt and burnt isn't the word for it. I'm surprised this thing still runs. The one on the firewall side/passenger is pretty much completely melted into a blob. AND one of the wires going to the Pass/Firewall glow plug was completely burnt off at the harness as in no connection.
So those things..
I'll be changing those. Is there anything else that I need to change while I'm in there? The van runs great when it's warm. It seems like it sort of hunts idle slightly but that's the only thing that doesn't sound like brand new. Acceleration is great, no noticeable problems or smoke at this time.
But I'm considering replacing the o-rings or rebuilding my injectors while I'm in there. The other part of me says if it aint broke don't fix it. What do you guys think?
LASTLY, what about the UVCH, any recommendations or models/sellers to avoid? I know about not using the Autolight GPs. I've got Motorcraft ZD11s on the way.
Ok I said lastly, but one more thing... I broke one of the wiring harness clips (brittle from heat). Is there a way to fix that?
thanks!
Nick
What I drive:
Ford E350 PSD 1995 --- Fast Diesel 385k Upgrades-Stancor Glow Plug Relay-DIY Stage 1 Injectors-Cat Out-Bigger Rear Tires-DIY SD Electric Fuel Pump system
MB 300d Turbo Diesel 1987 --- Fast and nice to work on
GMC Suburban 6.2 Detroit --- SLOOOW!!!
