For your engine to die the way you described sounds like an electrical/sensor issue, in addition to a lpop, cracked oil pu tube or failed valve in front cover.
I think we can prove the lpop by removing the plug on the filter head. Install a cheap pressure gauge and monitor oil pressure at that port. We cant measure lpo at the res because we know it isnt filling. So, fill your res, drain the oil back down to the proper level and try the pressure gauge deal.
Me thinks if you watch the gauge and observe lp oil, dies 10 min later as you describe then check your hpor and is discovered empty, then its not the lpop because we verified pressure elsewhere.
If its not the lpop, a cracked pu tube or check valve are the only other sensable failures, of which both requres engine removal.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
on the oil filter head, just above the flange that accepts the filter is a plug.
no you dont pull the engine to replace the lpop
Randy
Looks like yall are guiding him in the right direction. Don't forget that you can just pull the plug on the high pressure oil resivour and see if it is filling too.
Iraq vet and back home for good! 95 F250 SC 7.3PSD 4x4
Now out of the Army and located in South Florida.
Going to School to get ASE certified.
i hate to say it, but i had the truck towed to the mechanic. He is going to pinpoint the problem with me and help me get it running again. (I couldn't pass up this learning opportunity) I will keep everyone updated as to what the problem turns out to be. Thank you all for the help. I sure wouldn't have gotten this far without it!!!
the high pressure oil reservoir is not filling. So we need to attach a pressure gauge to the filter base and check the pressure while turning the engine over?
Thats what i would do instead of throwing a lpop at it, they arent cheap..
We need to verify your lpop is good before we go any further.
Randy
Even though its a pain one good thing about the HEUI system is that the engine wont run if the low pressure oil pump goes out. At least there's no chance of running the motor with no lube. I know that doesn't help but maybe it will cheer you up a little. :-) Good Luck.
