Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-09-2009, 02:46 PM   #76 (permalink)
well gentlemen... she started last night and purred for about two minutes before i shut her down to keep from waking the neighbors... (I have been using there shop to work on it since i do not have a slab to work on of my own) I appreciate all of the help and support i couldn't have fixed her without you guys. this was my first open heart surgery and hopefully the last.
1996 powerstroke, diy intake, 4" exhaust, hypertech 75 horsepower chip.
rob-08 is offline
Old 07-09-2009, 04:03 PM   #77 (permalink)
WOW you worked hard, but with VERY GOOD results. CONGRATS.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
Old 07-09-2009, 05:56 PM   #78 (permalink)
I'd say!!!! Good job.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 4:10 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP 1.0 exhaust housing * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 07-09-2009, 05:57 PM   #79 (permalink)
Good to hear ....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
Most people come here for the facts ...not a hug ...
action4478 is offline
Old 07-10-2009, 12:30 AM   #80 (permalink)
Your Awsome Rob!
IMHO The other guy's on this forum arn't bad either. LOL
Hey! You could change your handle to Awsome-Rob!
Jim
97F250 7.3 PSD 4x4 Ext Cab E4OD, 4:10LS, about 110k on the clock, Guages: Pyro,Boost,Trans. 4" intake, 3" Dp, 4" msrp exhuast, Cat MIA, Adj 10k, AMI Wheel chair lift.
ArrowHeadJim is offline
Old 07-10-2009, 02:09 PM   #81 (permalink)
haha i dont want to seem too ****y or anything... i did discover an oil leak which is frustrating. not to mention i blew a fuel line and replaced that last night. I cant win for loosing. im hoping some stop leak will fix the oil leak. does anyone have any ideas or suggestions that would prevent me from having to remove the oil pan again?
rob-08 is offline
Old 07-10-2009, 02:35 PM   #82 (permalink)
STurbo90's Avatar
My Photos: (9)
I don't think I would use any stop leak, the injectors live off of the oil and most agree not to use any additives in the oil.
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-10-2009, 02:43 PM   #83 (permalink)
so any suggestions as to fixing the leak without redoing everything that i just did? rtv sealer around the leak mayb? it is not under any pressure that i can tell. just dripping out. also i need the plate that the a/c compressor and other pulleys bolt onto on the driver side of the motor. i believe there are only four bolts holding it on. does anyone know what the name of the plate is and where i can find it?
rob-08 is offline
Old 07-10-2009, 05:03 PM   #84 (permalink)
If there is room , maybe able to inject some sealer(not to much or too deep) after cleaning ,with a turkey injector (for lack of a better description )Large syringe ...
Rick.....
Old 07-11-2009, 01:46 AM   #85 (permalink)
great idea... i will try it thanks very much
rob-08 is offline
Old 07-11-2009, 01:59 AM   #86 (permalink)
Hey Rob
Just hang a cat food can under there! LMAO
When it's full, just put it back int the top... Ah! I kill my self!
I once rebuilt a 351 winsor in the chassis. When putting the intake manifold on the cork gasket at the back of the valley kinda slipped. I put some sealer on or in there and life was good.
What do you have to loose? If it don't work, you can always pull it and redue or use the cat food can!
Jim
Old 07-12-2009, 02:46 PM   #87 (permalink)
i will definitely try the sealer haha catfood can is not bad idea either....
rob-08 is offline
