Did Ford make any F350 single wheel extended cab 4x4's? - Diesel Forum - TheDieselStop.com
Old 11-16-2008, 02:04 PM   #1 (permalink)
Every extended cab single wheel truck I find is an F250, Every F350 extended cab is a dually. Did Ford make F350 4x4's extended cab single wheel, or just standard cab and crew in single wheel style? Thanks
Bookshelf is offline
Old 11-16-2008, 07:37 PM   #2 (permalink)
Not that I've ever seen. I had a 96 f250 Extended cab that I put a straight axle under and 350 emblems. Made the diehard ford guys kind of scratch their heads.
97 F350 CC Dually 4X4 5spd 913 24V head S300/Ht3b Ranch hand .
sfd823 is offline
Old 11-17-2008, 12:19 AM   #3 (permalink)
Yup, ford only made the F350 4x4s in regular cab SRW, regular cab DRW, and crew cab SRW.....I've seen several Crew Cab 4x4 DRWs but they were all SRW trucks converted to DRW. THere also used to be a DRW extra cab truck running around town, but it was TTB so obviously converted.
Justin
'96 F250 Crew Cab Short Bus, E40d, 4.10, D60, Hard Knox RSK, SD Springs front and rear, Hard Knox Winch Bumper, Warn 10k winch, 38 gallon rear tank, 305s on stock Alcoas IDM mod
DixieJeeper is offline
Old 11-27-2008, 01:38 PM   #4 (permalink)
dieselcamino's Avatar
seen a few
theres a few 4 door 8 and 6 foot bed srw pstrokes around my area, there not the best looking trucks but they do exist
1996 f-250 PSD xlt single cab longbed
Tymar intake/Tymar Hpx line
custom 4 inch turbo back side pipe
swamps injectors
wildman 6 pos. chip
87' king pin d60
35" bfg mtr km2 on american racing rims
-Bio-diesel ready-
dieselcamino is offline
Old 11-27-2008, 10:48 PM   #5 (permalink)
In 4x4 you could get the F250 longbed supercab single rear wheel or the F350 longbed crewcab 4 dr single rear wheel. These were the only extended cab choices up til 1996 when they did the 4 door F250 Crewcab shortbed and F250 shortbed supercab. No dual rear wheels on 4x4 in our body style or previous except on standard body trucks. Both shortbeds were a real disgrace to me, as shortbed should never be offered on a 3/4 or 1T truck. Just my opinion apparently as now *all* trucks are shortbed, get a F850 and it's still a stupid-stupid 6 1/2 ft bed with an even stupider auto trans. Such is life, I made the auto mistake which I knew at purchase, but would never buy a shortbed anything.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
