Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 08-07-2008, 02:01 PM   #1 (permalink)
bockhold's Avatar
Send a message via AIM to bockhold
Dip stick tip is white
I am currently going through a water pump replacement. The engine has some oil left in the coolant system due to a bad oil cooler. The previous owner put a used cooler on with new seals. Ford told me to flush the system out with cascade and rinse it like 3 times to get the cascade out. Then replace all hoses and wp. While I’ve been flushing the system, every now and then I check the oil and find a white tip and some white stuff further up the stick. Ford said that is moisture in the oil system and it will take some oil changes to get that out. Ford also did the pressure check on the cooling system and said the wp is bad and the oil cooler is apparently not leaking. He said if the oil cooler is bad, the cooling system will be full of oil since the oil has a higher pressure than the cooling system.
What do you think about this problem? Im still wondering if the oil cooler is bad. Also I would like to send an oil sample to someone who does the testing. Who do you recommend?
Sorry for the long thread.
Jarrod
1997 F350 4door 2wd long bed white 7.3L Powerstroke, E4OD, C5 4:10LS diff 326K miles on org engine and been rebuilt again
http://i516.photobucket.com/albums/u...IM7683x320.jpg
http://i516.photobucket.com/albums/u...IM4402x320.jpg
All Stock for right now
bockhold is offline
Old 08-07-2008, 02:07 PM   #2 (permalink)
How many oil changes have you done since you noticed the water on the dipstick?...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer"....
Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
fordtransmissioncure.com
Special thanks to RacerX
racerxautomotive.com
action4478 is offline
Old 08-07-2008, 02:27 PM   #3 (permalink)
bockhold's Avatar
Uh... no more than two. At the most. I only put about 600 miles on it since I bought it.
bockhold is offline
Old 08-07-2008, 05:25 PM   #4 (permalink)
bockhold's Avatar
So you saying I should go ahead and do another oil change?
bockhold is offline
Old 08-07-2008, 05:39 PM   #5 (permalink)
When you drain the oil ,,how much water comes out first ?....
Is it decreasing in volume?....
Rick.....
Old 08-07-2008, 06:57 PM   #6 (permalink)
sloate's Avatar
I have had lots of luck with BlackStone, get a discount since you are a member
1994 F250HD, Single Cab XLT, 7.3 PSD, 5 Speed, 33in tires, level kit, straight piped! 12000lb warn, Canada made, 229000miles w/97 parts truck
1964 F350, 24v 5.9 Cummins not even close to broke in, New Nv4500, Turned Np205, Custom Dana 70s Front and Rear, Two 20000lb PTO winchs, 14" lift, 49" iroks!!, 97 PSD acc. with wire harness swap, 87 F350 frame (still sits in shop with fresh coat of JD green/yellow paint "Built Not Bought" 0 miles,
http://sloate.googlepages.com
The Most Powerful Diesel Engine in the World!
sloate is offline
Old 08-07-2008, 08:15 PM   #7 (permalink)
bockhold's Avatar
Well since you mentioned it, when I did the head gaskets, like a gallon of coolant came out of the oil pan. But haven’t changed the oil since. I guess I should do it this weekend or next. I have been using Rotella 15w40. Is the ford oil any better? Is Blackstone's web site blackstone-labs.com?
bockhold is offline
Old 08-08-2008, 08:56 AM   #8 (permalink)
MarkEkberg's Avatar
My Photos: (13)
Right now change it with the cheapest stuff you can find.
When there is no more water put better oil in. If you drained the water out, changed the oil once with in a short amount of time the remaining water should be gone. Oil temps run very high which would evaporate the water right out of there I would think.
1996 F-250 extended cab long box five speed. Home made Tymar, 203 Stat, 60 gal in bed fuel cell, 315/75's, no cat, no muffler, ebpv welded open 3" to 3" DP, Babies. 255K, still chugging, and still smoking when cold.
MarkEkberg is online now
Old 08-08-2008, 06:23 PM   #9 (permalink)
bockhold's Avatar
Maybe thats why theres the white stuff in it. The evaporated water. hmmm. I just bought some Rotella and a filter and gonna change it tonight or tomorrow.
bockhold is offline
Old 08-08-2008, 06:28 PM   #10 (permalink)
bockhold's Avatar
Oh I should tell ya that the oil has a tint of green. I asked the dealer that and he said thats normal for diesel oil. I have a hard time of believing that.
bockhold is offline
