Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 01-21-2008, 02:52 AM   #16 (permalink)
bigfootinindiana's Avatar
Originally Posted by BlindViper View Post
2 Cycle Oil
Powerservice and most commercial fuel adders contain little to no lubricity at all they contain more ingredients that break them down.
Its the process of removing the sulfur that removes the lubrication of diesel fuel. These compounds are whats found in fuel additives, if you look at the msds sheets provided by your link you will see these chemicals listed along with a solvent. The reason for using a solvent is to allow them to mix with your fuel in tank and to also increase the cetane level and remove carbon buildup. As far as I know there is a huge importance of having this solvent to incorporate the chemicals back into the fuel. That being said how can you really know that 2cycle is evenly mixing with your fuel? It is designed to be mixed with gas not diesel. I could see mixing castor oil with ether and adding this to your tank as Ive seen home made diesel from kerosene castor oil ether and amyl nitrate. I find it hard to believe that major companies like amsoil and powerservice would try to build a reputation on something that would do more harm than good. If 2 cycle is so great why not bottle it and sell it as "diesel magic fuel additive". Ive been using PS and contrary to your source have seen significant improvements in mileage. Check out SAE website for some good scientifically backed info on diesel lubricity. Also I thought i mentioned that distributors are supposed to add the lubricity back, but can you really trust that?
'96 F-350XLT 4x4, 7.3L, 175K, 3.55, E4OD, Western Pro Plow, AutoMeter Phantom II's, Tymar intake, 3" DPPI D.P. and 3.5" cat delete, 4" single stack kit from Black Cloud, 5"x36" mitre cut S.S. stack from MBRP, Gutted EBPV, Cali FPR, Stancor GPR, 215 Amp Alternator,Custom Battery Cables, SD starter, TS 6 Pos Chip
Truck Pics
bigfootinindiana is offline
Old 01-21-2008, 08:28 AM   #17 (permalink)
i see alot of people useing 4 stroke oil to help but what about new motor oil 10w30 15w40 ect????? will it be ok ? will it help lube the fuel system?
1997 f-350 4X2 7.3 PSD E4OD AUTO 4.10 Rear CC Dually Run Rotella Synthetic Oil, 150,000 +/- Miles...Came with a Superchips 1705 programmer....Things I've had to do ....Left Front Ball Joints, Air and Fuel Filters, Rear Fuel Tank, CPS, MAP, Cleaned EBP Tube and Sensor Replaced FPR Screen New 3" Downpipe and 4" Exhaust. Shimmed FPR Modified Air Box, Trans Temp Gauge, Boost Gauge, 8 New Glow Plugs. Not Sure What Else Yet...Any Ideas???
2004 Jayco Jayflight 26.5 5th Wheel (Truck pulls it like its not even there)
Acetcruiser is offline
Old 01-21-2008, 09:20 AM   #18 (permalink)
AggiePSD's Avatar
Originally Posted by cssutto View Post
This topic interests me, so I googled it and found this:
Flash Off-Road Diesel Fuel Articles
CSSJR
This article was on the same site as you linked to: Flash Off-Road
It's a presentation by Stanadyne on fuel qualities and additives. They encourage the use of an additive, stating that there are ASTM recommendations for fuel lubricity, etc. but the only government mandated regulation for quality of diesel concerns sulfur content. So now we know pretty much for sure that nobody is checking our fuel for lubricity, we are just trusting the fuel companies.
Although Stanadyne recommends an additive, they do sell fuel additives
But I guess they would be the authority on fuel delivery systems...
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
Truck & Other Pics - More Truck & Other Pics
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
AggiePSD is offline
Old 01-21-2008, 11:17 AM   #19 (permalink)
We are not talking about oil and water here. Yes they increase the cetane what is the point of increasing this level for lubricity of the fuel.? I run 2 cycle oil in my tanks have for 10k now best tank was 23.5 mpg avg is about 20. Why not bottle 2 cycle oil as something else? because everyone has done it.
1997 F-250 PSD, 130k, 4x4, Outlaw E4ODX, Standard Cab, reg bed, 3.55 LS rear, Swamps 225/146 injectors, Autometer Guages Pyro/Boost/Tranny, 3" downpipe, 3.5" adjusted exhaust, ts 6 pos chip, Tonys fun programs, Tru-Cool H7B, 285/75, factory alum rims, Western V-Plow, 6.0 intercooler installed not plumbed
I wish my lawn was Emo, cause then it would cut itself
Racerxautomotive.com for your upgraded E4OD/4R100 needs
BlindViper is offline
Old 01-21-2008, 04:32 PM   #20 (permalink)
We have established that the distributor is supposed to put a lubricant in diesel when he loads the truck at the terminal.
But why has no one asked what the distributor puts in it?
That is the $64 question because that is what we should put in our our pre 6.4 trucks.
Does anyone know what they add to the fuel?
CSSJR
If we do not wish to lose our freedom, we must learn to tolerate our
neighbor's right to freedom even though he might express that freedom
in a manner we consider to be eccentric.
cssutto is offline
Old 01-21-2008, 08:41 PM   #21 (permalink)
I never said that increasing cetane improves lubricity. The solvent is to properly mix the lubricants in the additives with your fuel in tank. Heres a simple analogy, think about making salad dressing, if you just mix oil and water they will not incorporate, but if you add some acid to the mix, say vinegar or lemon juice, they will incorporate quite nicely. Its the same idea with the additive. It just happens to raise the cetane level at the same time which improves combustion, has nothing to do with lubrication. And like I said before I have never seen any real scientific reasearch on the benefits of 2-cycle oil in diesel. If it works for you go for it. I'll stick with products backed by research for now until a bio fuel station opens up here and then I'll add that.
Jason
Truck Pics
Old 01-22-2008, 10:39 AM   #22 (permalink)
ok heres the thing diesel fuel is not water
Old 01-22-2008, 11:16 AM   #23 (permalink)
Your missing the point and acting like a smart***. Waist of my time and this website.
Jason
Truck Pics
Old 01-22-2008, 12:13 PM   #24 (permalink)
When you are mixing 2 oils you do not need a emulsifier
