Hi.
I have a 7.3 E-350 XLT cutaway and I can barely find any information on this vehicle. I bought the supplemental service manual and I may as well throw it in a fire (Ford expects you to buy a set of 5 manuals, and probably more for info on add-ons like the RKE).
Hopefully some kind soul out there knows:
1) Where the door lock relays are located on the E-350 (not the truck).
2) Where the remote keyless entry module is located on the E-350 (not the truck). No, I have no idea if there is one installed. It definitely WON'T be in the same location as the E-150 as that one is in the body and this is a cutaway.
3) Where the FOB programming jumper is located on the E-350 (not the truck). There is so much going on under there I'd probably need a photo to even have a prayer of knowing whether it is there or not.
I need to install a RKE somehow and I'd like to avoid tearing apart the entire cab to reverse engineer it. Failing this I'll probably have to bypass the original door wiring entirely and install my own relays.
Thanks.
Thanks.
