E4OD auto mileage vs. ZF-5?????????????? - Diesel Forum - TheDieselStop.com
post #1 of 17 (permalink) Old 11-06-2006, 09:35 AM Thread Starter
My Photos: (6)
Hey guys im lookin at a crew cab obs psd but its an auto. Just wondering what you all average for mpg with the e4od? I average about 19 with my truck with the zf-5. Thanks.
1997 F-250 xl, extended cab, 4X4, 5spd, , autometer boost and pyro gauges, 285/75 liberators, Dana 60 kingpin (freebee), bb fpr, and a big sratch in the paint, bdp stage 1s, dptuner 6 way chip, south bend clutch con o-fe,,,,,,,,,thats all for now.
chainfeed is offline
post #2 of 17 (permalink) Old 11-06-2006, 09:48 AM
Ragdude's Avatar
Re: E4OD auto mileage vs. ZF-5??????????????
Automatics, from people I've talked to with them, seem to get a little better mileage. Mainly, I'm sure, since they tend to gear an auto to run lower rpm's once locked into overdrive. A friend of mine has a very similiar truck but with his, an auto, at 70 mph he is turning about 500 +/- rpm's slower. And he get a couple miles per gal. better than me. But then, I am not as concerned about having to pay a tranny repair bill as he is [img]/ubbthreads/images/graemlins/smile.gif[/img]
Protect the 2nd Amendment!
It's the original homeland security act.
'96 F350,Dually,CC,5 spd.,stock.
'02 Excursion Limited, stock
B100 baby! Bring it home, to the American farmers!
Remember 9/11, and don't become complacent again
Ragdude is offline
post #3 of 17 (permalink) Old 11-06-2006, 12:16 PM
milner351's Avatar
My Photos: (5)
Auto's cost more to keep going for the long haul, almost gauranteed, but, they are faster and more trouble free when driving them, and with proper care and cooling can last a long time.... but not as long as a manual that is not abused, just MHO, and everybody has one.
In this case, yes, the AT has more overdrive than the ZF, so, a truck with the same tires and gears at the same speed will turn less rpms auto vs stick.
However, every time the AT converter is unlocked - the AT is using more fuel than an MT. Also the MT has more gears, but not the torque multiplication of an AT converter.....
it's a toss up from a usage stand point, it's really a personal preference.
Belleville, MI (Detroit / Ann Arbor)
'01 F350 cc lwb srw, Rebuilt engine, Rosewood rebuilt injectors, rebuilt turbo, soon to have 3.5"dp and 4" magnaflow exhaust, gauges, etc.
'69 Mustang 428CJ(ongoing project)
'86 Ranger 302/aod/8.8
'02 Focus wagon commuter
'86 Supra classic ski boat 351W PCM power
'54 Belair sedan, all original
milner351 is offline
post #4 of 17 (permalink) Old 11-06-2006, 12:55 PM
The ratios are 0.72:1 for the manual and 0.71:1 for the automatic. That's a difference of 1.4%.
If you are at a speed where the automatic truck is turning 2000 RPM the manual truck will be turning 2,028 RPM. I don't think that is enough to see on the stock tach, much less make ANY difference in fuel economy. And that's assuming the auto's torque converter is locked. If not, the auto will be turning a lot more RPM than the manual.
Casey_1 is offline
post #5 of 17 (permalink) Old 11-06-2006, 10:40 PM
Ragdude's Avatar
From the specs I looked at before buying my truck the "standard" gear ratio for a F350 PowerStroke with a manual tranny was 4:11 - 1, and the same truck with an auto was 3:73 - 1. A considerable differance. Of course you could order a different ratio but ...
Ragdude is offline
post #6 of 17 (permalink) Old 11-07-2006, 05:16 PM
greenskeeper79's Avatar
If you want MPGs, look for a 3.55 rear gear. That's gonna make the biggest difference IMO between an auto and manual. If you want towing power go with the 4.10 but expect a noticable milage drop.
Our CC gets 20mpg on the highway with the auto and 3.55 gears.
Gunga galunga...gunga -- gunga galunga.
97 F-250 CC 4x4 7.3L PSD E4OD
99 F-250 CC 4x4 7.3L PSD ZF6
ROTELLA 5W-40, MOBIL1 ATF, PENNZOIL SYNCHROMESH
greenskeeper79 is offline
post #7 of 17 (permalink) Old 11-07-2006, 09:59 PM
AggiePSD's Avatar
In town only driving in think the manual trans is superior. All the time waiting for the converter to lock when accelerating just feels like a huge waste of fuel to me. It's direct and quick with the manual trans, and would just have to be more efficient.
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
1968 IH Travelall 4x4
Work truck - 2008 F-350 6.4 PSD XL Crew Cab, Long Bed, Single Wheel, Torqueshift, 3.73LS, 4x4
AggiePSD is offline
post #8 of 17 (permalink) Old 11-07-2006, 10:14 PM
rednck21's Avatar
thats a huge difference. id say you are comparing a 4.10 in your truck to a 3.55 gear in his [img]/ubbthreads/images/graemlins/shrug.gif[/img] also, im pretty sure 3.73's were only offered from the factory in the 99+ trucks.
2000 F-250, reg. cab, 4x4, XLT, 7.3, built 6/00-forged rods!, DP Tuner F5, AFE stg. 2, MBRP 4", Autometer Ultralight boost/pyro/trans temp gauges, 285 BFG's
2011 F-150, 2wd, XLT, Ecoboost
rednck21 is offline
post #9 of 17 (permalink) Old 11-08-2006, 08:53 AM
milner351's Avatar
My Photos: (5)
3.55 is the only way to go for mileage, also stick with conservative tires and keep the tire size close to original.
as for the OD ratio's I don't recall the numbers exactly, but at some point here someone had posted them, I thought the e40d was .71 and the zf .75... not a huge difference either way.
There is one fella here who put 3.08 gears in the back of his 2wd.... loves it for the mileage, and can still outpull a gasser!
post #10 of 17 (permalink) Old 11-08-2006, 10:47 AM
Casey_1 is offline
post #11 of 17 (permalink) Old 11-08-2006, 10:42 PM
Ragdude's Avatar
Not positive, but I do know my previous truck, a '79 F250 camper special, with a 460 & auto, came with a 3:73 rear end.
milner351, man you'd have to have an auto with 3:08's. But, once it was rolling you should be able to do 75 mph around 1400 rpm's. Thats probably too low unless your always running empty. [img]/ubbthreads/images/graemlins/shrug.gif[/img]
Ragdude is offline
post #12 of 17 (permalink) Old 11-08-2006, 11:13 PM
On my 97 I am only getting 16 mpg at the very best with stock tires, I have an auto with 3.55's. I wish I could say I was getting 20 mpg
97 F-250 PSD Extended Cab, long box, 4x4, 3"down pipe, 4" exuast, 5" tip, cat delete, Tymar Intake, Tony Wildman 4 position chip, Issopro 3 guage pod, 2" leveling front spring, 285/75/16 Mickey Thompson Radial MTX's, flip up gooseneck, 3.55 gears, 95,000 Miles
Thanks Tony!!!!
Guages from:
Wish list: Beans stage 1's, IC inlet tubes from Banks, Trans Command, BTS Trans
1985 Chevy C10 2wd shortbox,355ci,balanced internals,420hp at the flywheel
2001 Impala police interceptor
2002 Crown Vic Police Interceptor State Police Blue (supercharger soon)
Just a broke 23y/o college kid on a budget, wanting to do much more with the truck!!
9132bulldog is offline
post #13 of 17 (permalink) Old 11-08-2006, 11:58 PM
johndeerebones's Avatar
In our year f250 and 350's had only two options factory, 3.55 or 4.10. Lower in the heavier trucks.
Sold, back when the snow was on... (Jan 2010!)
1997 PSD 3/4 ton 4x4 SC LWB SRW; 5 spd; 3:55; K&N open element/homemade intake; gutted EBPV piston, plugged hole; 3 in. downpipe; SCMT 1705; shimmed to 70 psi; 120,000; TTB
DiPricol 0-60 white face boost gauge, DiPricol 0-1600 white face pyrometer, SOLD in between gauges for now; A-Pillar mount for now. DIY 160cc Injectors.DIY IDM mod. ValAir O-FE w/3400# plate; Front and rear tank filler neck mods
johndeerebones is offline
post #14 of 17 (permalink) Old 11-09-2006, 12:01 AM
rednck21's Avatar
im talking about powerstrokes...
rednck21 is offline
post #15 of 17 (permalink) Old 11-09-2006, 12:04 AM
rednck21's Avatar
thank you [img]/ubbthreads/images/graemlins/wink.gif[/img]
rednck21 is offline
