Can anyone that's removed the front pump from an E40D point me in a direction? I've got all of the retaining bolts out, and the front cover loosened up. Just cannot get it to come out. I've got the front seal removed, but not the bearing that the converter rides on. Is there a snap ring or something else I need to remove?
AllData gives a pretty good diagram, and it looks like everything should come on out as it is. Figured I'd ask before I break something though.
Checked the ATSG book. Two of the holes should be threaded so you can attach a slide hammer. Book shows a slide hammer in each. You might be able to just thread a bolt in each, and use an improv prybar technique to pull it. Doesn't show the bolt size.
I'll second the slide hammer method as when we pulled mine out it took quite a bit of effort to get it out squarely with 2 slide hammers as theres a large square cut 0-ring around the OD of the pump housing that makes for a tight fit to the case.
Be careful & go slow also when reinstalling as things need to be lined up perfectly for it to fit.
Best of Luck
Brian
95 F-250 XLT,SC,4x4,TDE1,LWB,4:56's,Dana 60,E4OD(lightly tuned),Tymared,Swamped,Lifted,rear disc brakes,6 pos chipped & a pile of other odd & end mods.Trucks,Parts & Misc. Pics 05 F250 V10 too
If you don't have a slide hammer I think I used some angle iron against inside of the bellhousing to pull from with the two bolts. Popped her right out.
Travis
1997 F-250 HD 4x4/OR SC LB XLT PSD E4OD 3.55LS, TDE1, Baby Swamps (150/146/A), BTS Trans, BTS programming, Front and Rear Replacements, Gooseneck, Autometer Pyro, Trans Temp and Boost in Rockin' S Pod, Cab/Clearance Lights installed, Tymar style intake, 6.0 Intercooler, Tru-Cool Max tranny cooler, Warn Premium Hubs, Shimmed FPR, Gutted EBPV, Super Duty 3" DP, 4" Exhaust, 175,000 mi., 7400 lbs., 310 HP 559 TQ
the filter attaches to teh pump so remove it, you can take teh input shaft half way out and use it as a pry bar side to side to wiggle it out, if it will not go then a slide hammer is the only way, but you want to replace the front bushing too.
__________________ Sold to JCart , 1997 F250 FireTruck Red,CC SB,auto( Presicion TC, HD-2Tugger),5" exhaust, Swamp 140cc injectors, TWildman 4-pos chip,open air cleaner, I/C w Banks intake, ,AIC,dual electric fans,Sky mfg RSK w/ D60w/ARB locker,she's well taken care of now pictures
2004 Dodge 3500 twin turbo 525hp rocket
