e4od wont shift past 2nd - Diesel Forum - TheDieselStop.com
post #1 of 13 (permalink) Old 02-19-2010, 11:44 AM Thread Starter
smokinstroker's Avatar
My Photos: (10)
well my truck ended up in my pond dont ask how but the engine was out of the water. i got pulled out and drove it down the road and everything was fine. so i let it sit so it could dry out. so about a 5 days later i got in it and started and headed down the road and it wont shift past 2nd now. so i droped the pan and it had no water in it. so i checked the range selector switch and it was full of water so i put a new one on it and its still doing the same i dont slip nice firm shifts it just wont shift past 2nd. i know nothing is broke internaly. the trans only has 3000 miles on the rebuild. theres no od light flashing. i am thinking the computer got fried. i dont know what problem is
we are not here for a long time we are here for a good time
other toys
92 ranger extended cab with 310,000 miles
86 f-250 4x4 6.9 diesel 450,000 miles and still going strong
87 f-350 xlt 4x4 4 door 6.9 340,000
95 f-150 4x4 5.0
97 f-350 exteded cab 4x4 NATHAN P3 TRAIN HORNS two whipps, SWAMPED INJECTORS,head studs,cometic head gaskets, h2e turbo,lots of boost almost too much,joes idm, built e40d 4.10 gears,6 pos chip,open ellement air filter k&n #41-1400 hypermax 4in dp,kitty is in the litter box.10k mod shimmed,autometer gauges boost,oil pressure, pyro,trans temp, 6 in lift,6' traction bars, diamondplate toolbox, 5in stacks,lighted ford logo in the grill
smokinstroker is offline
post #2 of 13 (permalink) Old 02-19-2010, 12:27 PM
Bill1013's Avatar
drinking beer in michigan SWAMPED INJECTORS well my truck ended up in my pond OK cut it out! My sides are splitting.
I suppose the ice was to thin .
Seriously tho. Check the harness pluggin on the passenger side. I would bet it's full of water (ICE) . It's behind the metal shield, kind of hard to get at. Unlock it, don't pry it out, pull it out with the wire harness. Brake cleaner, not WD40, is good to clean it out.
99.5 F350 XLT Lariat 4X4 4R100 4.10 DW CC LB Centurion conversion, 183K miles Garret Turbo, Radio SD &Tape, SP Performance 40-60-80 chip, 100 Gal.Transfer Flow W/Trimax Control Aux. fuel tank. ScanGaugeII, Boost, EGT, Trans. Temp. Oil Temp. Build date 03/99
92 F350 2WD 7.3 IDIT E4OD CC LB dually Banks turbo US Gear O/U, 79K on the engine. 129K body.
Have AutoEnginuity W/Ford enhanced. Lima OH area.
My mind works lightening fast. One Flash and it's gone forever.
Bill1013 is offline
post #3 of 13 (permalink) Old 02-19-2010, 12:29 PM
Mine did the same thing (well not in pond) but mine was a solenoid in trans. 300 bucks and i was on my way.
'96 F-250 178,500
'95 EB 193,000
'05 Excursion 4x4 V10 78,000
msuforeman is offline
post #4 of 13 (permalink) Old 02-19-2010, 04:13 PM
midwestconnection's Avatar
The VSS Sensor and it's connecting wire on your rear end will cause shifting problems for sure.
Bumper to bumper, Full Synthetic!!! Rotella T 5-40(7.3L) -- Mobil 1 Mercon V(E40D) -- Amsoil Extreme 75-90(Danas 60) -- Detroit Lakes, Minnesota -- "Boating has always been a rich mans hobby". -- 1996 E350 XLT Club Wagon 15 Passenger Van. -- Purchased 10-21-2009 for $700 cash with 620,000 miles on it! -- It's mint and beautiful! -- I love it! -- I am 64 years old and a professional mechanic and truck driver for over 45 years. --I am now a rich man driving a $50,000 prime time Ford that gets 21 MPG(HWY) & 16 MPG(Town).
midwestconnection is offline
post #5 of 13 (permalink) Old 02-20-2010, 12:02 AM Thread Starter
My Photos: (10)
this happened in the summer. just got around to looking at it. the speedo works fine and the converter locks up in 2nd just wont shift past 2nd.
other toys
95 f-150 4x4 5.0
post #6 of 13 (permalink) Old 02-21-2010, 06:18 AM
That isn't your problem. There is something mechanically broken inside the transmission.I didnt say that somebody else did just thought i would repete it. i dont have a clue whats wrong but i can recomend a good trans guy.
dougs250 is offline
post #7 of 13 (permalink) Old 02-21-2010, 11:04 PM Thread Starter
My Photos: (10)
nothing is broke internaly water dont brake parts
other toys
95 f-150 4x4 5.0
post #8 of 13 (permalink) Old 03-12-2010, 10:54 AM
strokinit7.3's Avatar
Thumbs up
Well few weeks ago two 12packs later at the mudd hole my 93 7.3 was in water over the seats, fluid was a milky pink full of water, did the same thing wouldnt shift past 2nd, droped the pan it was the solenoid < just ordered it was 69.00 $ on ebay put a hose on the top trans cooler line, cranked the motor up put in D hold break until all old fluid is out of the system, replace with new until it turns nice bright red. change filter and your good to go! solenoid part number is 26393AR just type in "E4od parts" in a google search you will find a number of sites who sell it. hope this clears things up i was in the same boat, talk to 4 trans shops , all said it needed a rebuild BULL****, finally found a guy who knew his stuff and told how to fix.
strokinit7.3 is offline
post #9 of 13 (permalink) Old 03-12-2010, 05:27 PM
WorkinMan's Avatar
Ever seen a diesel that ingested some water? I have... and it was FULL of broken parts. Not a pretty sight.
1996 F250 XL 4X4 Automatic, 3:55 gears, Regular cab. Cruise control mod. Big tranny cooler. Autometer Phantom boost, pyro and tranny temp guages. Hypermax downpipe. Homemade open air intake. TS 6 position chip. Sonnax valve and tricumulator springs. Billit torque converter. 215,000 miles so far.
REAL TRUCKS DON'T WEAR BOW TIES !!
WorkinMan is offline
post #10 of 13 (permalink) Old 03-13-2010, 04:16 AM
If it is full of broken parts then it was a prexisting condtion, were the broken parts there before the water?? you wouldnt know because you probly havnt droped the pan in couple years. WATER WILL NOT BREAK PARTS! the only thing that it may damage is the diaphram it is water soliuble this diaphram is located in the solenoid pack> when the diaphram getts enough pressure it causes the solenoid pack electronily thift to the nxt gear! EX. 3rd then OD. with out this working the tranny will only go through the gears that you are manually able to shift! When changing this part out you must ensure that ALLL of the water is flushed out of the system!!!! otherwise your out 70 $ and thinking its another problem instead.
Dougs250 you were wrong.
post #11 of 13 (permalink) Old 03-15-2010, 09:02 AM
ok so when you replace this solenoid make sure you buy it new NOT the reman..... it is not even rebuilt just cleaned an shipped out as is!!! i spent over 130$ in atf flushing this tranny out an now i have to go through 10 more qts to drop the pan again. so save some time and money and buyit new.
post #12 of 13 (permalink) Old 03-26-2010, 12:39 PM Thread Starter
My Photos: (10)
the engine will let lose. but the trans wont my engine was no where near the water. i am not that stupid lol
other toys
95 f-150 4x4 5.0
post #13 of 13 (permalink) Old 03-16-2012, 06:16 PM Thread Starter
My Photos: (10)
well its fixed is was a stuck valve in the valve body.
other toys
95 f-150 4x4 5.0
