early 99 turbo on a 96
I have a 96 F350 and just bought an early 99 turbo w/wastegate out of a 550 was wondering if anyone knew what it takes to make the swap or if its worth it I know the exhaust inlets look different but is the turbo pedestal the same???
1989 F-250 7.3 ZF5spd ext cab 4X4 Banks turbo kit, no mufflers, 6.9Linjector pump turned way up(My original bit the dust had 2 spare 6.9L) Brass Button Clutch built by KC Clutch builders The Big one, Dual Mass Flywheel. bucket seats, 256,000 miles. 65 MPH@2300RPM
96 F-350 dually extended cab 170,000 miles, 2wheel drive automatic
7.3 AFE intake, TS performance 6 bank-Gone due PCM getting cooked with chip in, Bully dog valve body, Gear Vendors overdrive gear splitter, BD exhaust brake, Air Lift air springs and compressor on rear end, Running WVO over 20,000miles.
