Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 07-24-2008, 10:36 PM   #1 (permalink)
electrical problem
Mechanic repaired rear electrical windows and when i picked up the truck the speedometer and rear fender lights stopped working. Also the transmission shifts very hard. I checked the fuses and everything looks okay. Any suggestions.
Thank you
Scooby
escooby is offline
Old 07-25-2008, 03:56 AM   #2 (permalink)
STurbo90's Avatar
My Photos: (9)
is the check engine light on?
1995 F350 PSD,CC,LB,E4OD,4WDw4:10LS
IDM Corrosion
Underdash Gauge Pod
Front Tow Hooks
STurbo90 is offline
Old 07-25-2008, 10:23 AM   #3 (permalink)
eagleeye's Avatar
Make sure all of your brake lights work. Sometimes when the third brake light is burnt out it can cause irratic shifts. Also check your VSS in your rear axle.
Travis
1996 Extended Cab Long Bed XLT, 4x4, 3.55LS, Tymar Intake, Diamond Eye Performance 4" Exhaust, Meyer C-8 Plow, Timbren Load Levelers
Case 1845c Uni-Loader
PowerStrokes And Duck Hunting-It Doesn't Get Any Better
eagleeye is offline
Old 07-25-2008, 08:31 PM   #4 (permalink)
electrical problem
thanks for the quick response! I checked the third brake light and it is out, I'll replace the bulb tomorrow and let you guys know if that solved the problem.
Thanks again
Scooby
escooby is offline
Old 07-25-2008, 08:32 PM   #5 (permalink)
no check engine light. thanks
escooby is offline
Old 07-27-2008, 09:29 AM   #6 (permalink)
Third brake light now working but still no speedo and still eratic shifts.How do i check vss?
escooby is offline
Old 07-27-2008, 08:01 PM   #7 (permalink)
The VSS is in top of the rear diff. You can pull it, clean it, check its connections and see what happens. If you want to replace it, its fairly inexpensive at any auto parts store.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Past 2002 F-350 Lariat, Supercab 4X4, Toreador
Red, 7.3L, Auto, DRW, Fully Loaded.
Past 94.5 F-250 Lariat, Supercab 4X4, 5 spd 7.3L PSD.
DRJ48 is offline
Old 07-29-2008, 12:31 AM   #8 (permalink)
DABOSS's Avatar
Is your O/D light flashing on your shift lever (assuming this is an auto)? I know you said that you checked your fuses, sometimes it is easy to glance past one especially when they all look the same (fuses inside the truck, driver's side). Good luck.
'96 F250 XLT, 4WD, Ext Cab, E4OD, 4.10, ATO Performance Transmission, ATO Heavy Duty Transmission Cooler, Tymar Intake, Tymar 3x4 DP, Tymar Coolant Filter, no "kitty", gutted EBPV, USA Made Powermaster Denso 9051 Starter!...
DABOSS is offline
Old 07-30-2008, 09:03 PM   #9 (permalink)
Unhappy
replaced vss, still no speedo and still shifts hard.
escooby is offline
Old 07-31-2008, 06:31 AM   #10 (permalink)
eagleeye's Avatar
I had your symptoms years ago on my '94 F-250 gasser. It turned out to be a fuse in the underdash fuse panel. If all of your fuses are good, ask your mechanic where he made the widow repair and start there.
Travis
eagleeye is offline
