Mechanic repaired rear electrical windows and when i picked up the truck the speedometer and rear fender lights stopped working. Also the transmission shifts very hard. I checked the fuses and everything looks okay. Any suggestions.
Thank you
Scooby
Make sure all of your brake lights work. Sometimes when the third brake light is burnt out it can cause irratic shifts. Also check your VSS in your rear axle.
Travis
1996 Extended Cab Long Bed XLT, 4x4, 3.55LS, Tymar Intake, Diamond Eye Performance 4" Exhaust, Meyer C-8 Plow, Timbren Load Levelers
Case 1845c Uni-Loader
PowerStrokes And Duck Hunting-It Doesn't Get Any Better
thanks for the quick response! I checked the third brake light and it is out, I'll replace the bulb tomorrow and let you guys know if that solved the problem.
Thanks again
Scooby
The VSS is in top of the rear diff. You can pull it, clean it, check its connections and see what happens. If you want to replace it, its fairly inexpensive at any auto parts store.
2004 F-350 Lariat, Supercab 4X4 FX4, DRW
Dark Toreador Red/Silver, 6.0L, Torqueshift Auto, ESOF, 4.10 LS, Camper Package, Dual Alternators. Build Date 6-8-04, Eng 5-28-04, Lance 9.5 Ft Camper.
Is your O/D light flashing on your shift lever (assuming this is an auto)? I know you said that you checked your fuses, sometimes it is easy to glance past one especially when they all look the same (fuses inside the truck, driver's side). Good luck.
'96 F250 XLT, 4WD, Ext Cab, E4OD, 4.10, ATO Performance Transmission, ATO Heavy Duty Transmission Cooler, Tymar Intake, Tymar 3x4 DP, Tymar Coolant Filter, no "kitty", gutted EBPV, USA Made Powermaster Denso 9051 Starter!...
I had your symptoms years ago on my '94 F-250 gasser. It turned out to be a fuse in the underdash fuse panel. If all of your fuses are good, ask your mechanic where he made the widow repair and start there.
Travis
