Engine Oil stabilizer??? - Diesel Forum - TheDieselStop.com
Old 06-17-2009, 06:41 PM   #1 (permalink)
Hey ya'll.. I was wonderin, Do any of ya'll run the lucas engine oil stabilizer in your powerstrokes?? I have some and was thinkin about runnin some in my stroke but dont want to mess somethin up or create an oil leak that aint there.. I have run it in a chevy 454 motor and trans and it worked good.. But I ran the injector cleaner in my dodge cummins and the injector pump started leaking and I also ran the transmission stuff in it and it started leakin also.. Just wonderin if anyone has had any leaks pop up from using the lucas in there fords??? Thanks, TractorMike
1989 Dodge 250LE, 4x4, cummins, stright piped, pump tweaked, more mods in the future
my new toy, 1996 f-350, crew cab, 7.3 diesel, 5spd, mods in the future
TractorMike is offline
Old 06-17-2009, 06:55 PM   #2 (permalink)
bugman's Avatar
My Photos: (18)
I personally wouldn't put anything into the oil on these engines except for oil. If you change your oil and use a good diesel rated one you should not need anything else in it. Most additives are just snake oil getting you to spend your money on them with no additional benefits.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 06-17-2009, 06:58 PM   #3 (permalink)
blageurt's Avatar
Only use the correct oil as specified by FORD /International . . . Lucas can cause injector issues due to foaming and improper viscosity and maby even permanent damage . . .
95 E350 PSD HD Cargo , BB shim , E4OD , B&M aluminium Trans pan , Twin HD coolers , Cat sleeps with the fishes , 3:55 D70FF, Michelin LTX " E " , DP flashed 60 Tow , 140 V idm , Autometer Triple Pillar Guage pod , New Injector O-rings /IPR /lift pump / filterbowl @ 235K , Timbrens SES kit , replaced lift pump /ICP/ IDM @ 256 K
1977 F350 Dually Dump , 460 , 429 POLICE heads , 4:56 D70FF, Edelbrock Intake , Holley 850 dbl pmper ,MSD IGN , Custom HiPo C-6 Trans , Dual Exhausts , Bridgestone "E" Tires
1983 KZ1000R , Yoshimura Stage I
1982 KZ1000 , 1045 Wiseco , Turbo ready
1990 KX500
blageurt is offline
Old 06-17-2009, 08:04 PM   #4 (permalink)
X3...dont use any additives in a PSD.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
Old 06-17-2009, 09:37 PM   #5 (permalink)
i used some of the synthetic lucas oil stabilizer my last oil change. i think that it is helping my truck run a little smoother at idle at least. i do 10,000 oil changes on dino oil and usually idles a little rougher near the 10,000 mark but haven't noticed that at all this oil change. i use oil between changes and i was hoping that it would help with that but it didn't seem to make a difference. also, just within the last week i had one instance that it wouldn't start on its own ( had to use starting fluid ) and cranked a little longer than normal a few times right around the same time. i'm not sure yet if it's related to the lucas or not. i've been hanging around the bitog site and heard a lot of good things about this auto-rx product that supposed clean your engine out real good along with provide some friction modifier additives to help reduce wear and i've been thinking about using some of that on my next oil change.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 06-17-2009, 10:34 PM   #6 (permalink)
Ok ya'll thanks, Thats what I was wantin to know.. I don't believe I'll use any in the stroke then, dont want any surprise oil leaks or injector problems.. I never put any in my dodge after the tranny and injector pump started leakin after the lucas.. was always afraid it would spring an oil leak somewhere I didn't want one.. thanks ya'll
Old 06-18-2009, 01:56 PM   #7 (permalink)
riceburner's Avatar
I have been working on 4 oil changes and still haven't gotten all the Lucas oil treatment from the oil, man did it run like crap after I put that stuff in.
riceburner is offline
Old 06-18-2009, 02:57 PM   #8 (permalink)
if you pumped the oil out of your hpop reservoir and pulled the valve covers and pulled the oil rail plugs, that would help get an extra 3 qts of oil out.
sdan27 is offline
Old 06-18-2009, 10:23 PM   #9 (permalink)
The only recommended additive i am aware of is Fleetrite CH1824392 or Lubrizol 888. These are antifoaming agents.
Randy
Old 06-18-2009, 11:20 PM   #10 (permalink)
pjwoolw's Avatar
My Photos: (5)
I've been running the Hotshots product in the 05 with great results. I'm going to try it in the 97 next oil change. Allot of folks consider it snake oil. But I am impressed with it.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 06-19-2009, 12:48 AM   #11 (permalink)
riceburner's Avatar
I drained the top end oil, and put in some Prolong like was suggested. It runs much smoother now and not near as noisy either. I think the longer I run it the better it is getting finally.
Old 06-19-2009, 01:43 AM   #12 (permalink)
pjwoolw's Avatar
My Photos: (5)
I did the same not to long ago. Made a big difference. Many don't think it's necessary and are really down on the HPOP flush. Made me a believer.
Pete in San Ramon
pjwoolw is offline
Old 06-19-2009, 01:20 PM   #13 (permalink)
What about Additives? Scroll down for engine oil results.
PSDWILDERNESS is offline
Old 06-19-2009, 07:16 PM   #14 (permalink)
Window&Door's Avatar
For Ford Power strokes, specifically, Lucas recommends one quart of the pure synthetic additive. Could that be a variable in the controlled test?
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 06-19-2009, 09:14 PM   #15 (permalink)
riceburner's Avatar
Put it in and let us know.
