Engine Oil stabilizer??? - Page 2 - Diesel Forum - TheDieselStop.com
Old 06-20-2009, 02:15 PM   #16 (permalink)
Window&Door's Avatar
Originally Posted by riceburner View Post
Put it in and let us know.
Well, no, but thanks. I just wonder what the test would reveal using the synthetic additive that is recommended for our motors. Not that I'm anxious to spend another $20 per oil change... unless its worth it. I'm not an oil expert but I sure wouldn't run the standard stabilizer when the bottle calls for the synthetic, so why bother testing the standard? And what about Prolong? have you had good luck with that? If there is an additive worthwhile I would spend the money on it for my truck.
1996 PSD supercab longbed 4x4 XLT white/grey int. TS 6 position chip, New turbo w/1.00 Turbine housing 3" dp 5" exh. no cat, no muff 6" stainless slash tip. DIY Napa intake Sony Xplod stereo, door speaks, amps and subs. Autometer gauges and pod E4OD 150k miles. GEAR VENDORS! One piece rear drive shaft, two piece front shaft 4" Superlift on Weld wheels wrapped with Pro-Comp Xtremes. Clean. All rebuilt fuel system/new pump, new SD Intercooler, Modified Banks Pipe kit. **********SOLD**********
2002 Silverado 5.3 1500 2wd stock Pioneer Navi 1 daily driver 110k miles
1996 Kawasaki SXI750 twin big Mikunis factory pipe R&D head/rideplate kustom kut solas impeller ported/polished big power, little ski 58mph w/235lb rider on VP-C14
1988 Suzuki LT500 Quadzilla
1978 Suzuki FZ50
1977 Suzuki FZ50
1978 Motobecane 50V
Window&Door is offline
Old 06-20-2009, 06:46 PM   #17 (permalink)
well, like i said in an earlier post, with the synthetic lucas, my truck does seem to run a little smoother especially on long oil changes. i intend to send in an oil sample when i drain my oil ( probably next week ) and i'll post the results. i intend to use auto-rx on my next oil change and go through the cleaning process it recommends and possibly continue to use if afterwards for the friction modifiers it offers.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
Old 06-20-2009, 10:52 PM   #18 (permalink)
riceburner's Avatar
It has been recommended to add Prolong when you change the oil in the top end, that is what I did and it seems to work really good. My motor runs much smoother now and doesn't make nearly as much rattling noise.
Worst mistake I ever made was putting in the Lucas non-synthetic stabilizer, (at 60 it bucked liked the wheels were coming off) since it didnt help much on the first oil change I tried it again (what a dummy). Then on the next one I tried some of the synthetic additive, it ran just as bad as before.
The reason I tried it in the first place was; after I used some of their Diesel fuel additive it seemed to make it run much better, hey, if a little is good allot must be better, right?
Finally after 3 oil changes with no additives, then recently changing the oil in the top end it is finally starting to run like it use to.
riceburner is offline
Old 06-20-2009, 11:33 PM   #19 (permalink)
bugman's Avatar
My Photos: (18)
It has been recommended to add Prolong when you change the oil in the top end, .
Just a FYI for you in case you do not know, the "Top End" oil is the same oil as is in the oil pan. It circulates together.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 06-21-2009, 12:30 PM   #20 (permalink)
riceburner's Avatar
That is the theory.
Old 06-21-2009, 01:17 PM   #21 (permalink)
bugman's Avatar
My Photos: (18)
Not theory but fact. The oil goes from the low pressure oil pump to the high pressure oil pump then it is delivered to the injectors through the high pressure oil lines and cylinder heads. The injector uses the oil pressure to inject the fuel into the cylinder and then out of the injector to the valve train area. From there is flows back down to the oil pan. If is was a closed system when you pulled your valve covers off and ran the engine you would not see any oil coming from the injector but have a return line connected to it to recycle it to the hpop.
Jim
bugman is offline
Old 06-21-2009, 01:34 PM   #22 (permalink)
riceburner's Avatar
Your sir are correct, and you know I have found over the years that every time a designing engineer has designed something for use they always have taken everything into consideration and the end results are always as they expected.
