engine oil way over full - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 09:58 AM   #1 (permalink)
Got a 1997 F350 7.3 . I checked the engine oil level and it way over full all the sudden and kinda clear looking. No noticable smell. I can't think what it would be besides fuel. Any ideas of what it is and how it got there. Thanks.
1997 F350 100 gallon tank with hotstick, Vormax filter and vegtherm
gomerbull is offline
Old 03-03-2005, 10:27 AM   #2 (permalink)
TravisT's Avatar
Re: engine oil way over full
Check this out.
I would stop driving it. If it's milky then it could be water contamination. But it could be fuel. Check your fuel filter housing. Pull the filter and if the fuel is dark brown in there then you have oil in your fuel and fuel in your oil. Likely caused by bad injector o-rings. But read that post before you drive much more.
Well loved 1997 F-250HD 5-SPEED 4X, New 4.10s (PRECISION GEAR), Truetrac (DETROIT LOCKER), Hubs (WARN), 4"/7" lift (SKYJACKER), 35x12.50 (PRO-COMP), 100 Gallon VO Tank (greasel.com), Dominator 66 Turbo, Stage 1 Injectors, 6 Position (BDP), Clutch (LuK), 6.0 Intercooler (4WP Dumpster), DP & Guages (SCHEID DIESEL), 4" exhaust - properly loud (BD-POWER), 203' Tstat (dieselsite.com), Prerunner bar (N-FAB), DIY Electric Fuel, Raptor-150 Pump, HID headlamps, spots, and fogs, 225000 (s)miles, 2005 Emblems, 2002 HPOP not installed
TravisT is offline
Old 03-03-2005, 10:29 AM   #3 (permalink)
TravisT's Avatar
BTW, welcome to the site!!
TravisT is offline
Old 03-03-2005, 10:45 AM   #4 (permalink)
Sounds like that's what it is alright. Thanks for the info and the welcome.
Old 03-03-2005, 01:47 PM   #5 (permalink)
tallfarmboy's Avatar
My Photos: (11)
Gomerbull,
Where in Missouri are you from?? Nice handle by the way....we had an old Jersey gomer bull....he thought he was hot stuff...
Tallfarmboy
Jared Jeffries
Sold: 1997 F-350 CC 4x4
"New Rig" 2003 F-250 Lariat CC 6.0L EDGE w/Attitude Monitor, Automatic, 4" Exhaust
Truck Pictures Show Me DJ Service
tallfarmboy is offline
Old 03-03-2005, 03:42 PM   #6 (permalink)
I'm in Lathrop Mo. "Former mule capital of the world"
I think you're the first to admit to knowing what a gomerbull is.
[img]/ubbthreads/images/graemlins/warmsmile.gif[/img]
Old 03-03-2005, 08:59 PM   #7 (permalink)
My Photos: (32)
Now that I know what a Gomer Bull is, I'll just refer to ya' as GB!
Welcome aboard!
Sound very much like the classic injector o-ring failure... as stated above, checking the fuel filter for dark fuel is another indicator...
God Bless,
TC
97 F350 XLT, 4x4, Toreador Red, CC, PSD, MLE0, ZF5, 3.55 l/s, LUK clutch,Velvet Rides, ISSPRO gauges, v/cover vented to tailpipe, DPPI downpipe - modded to 4" right below firewall seam, open element intake using Duralite filter, coolant filter mounted between washer fluid bottle and jack, gutted EBPV, 99+ I/C installed using early 99 Y-pipe and custom pipes, 4-pos chip, BigBopper Seat Mod, Bilsteins, 130cc injectors, homegrown 4" exhaust, uses 36" Magnaflow muffler (Model #12773 body is a full 30" long - nice and quiet!) Custom Fuel System using Carter electric pump, Aeromotive regulator and frame-mounted filters...
2003 Tahoe MS27TT (27' Lite travel trailer), Prodigy Brake Controller.
1991 5.0 LX, runs 12.57 @ 109 mph
My Intercooler/Fuel System Install Webpage (section on CCV Mod too): http://members.localnet.com/~boys3/
TimC63 is offline
Old 03-03-2005, 09:53 PM   #8 (permalink)
You may want to also check the fuel lift pump behind the fuel filter, if the diaphram ruptures it will pump fuel into the block
Where ever you go, there you are.
96 F-450 S.D. bone stock 7.3L DIT
1957 chevy stepside P/U 350 port injected
rayjay717 is offline
Old 03-04-2005, 09:55 AM   #9 (permalink)
Fuel filter is full of oil to. Does that rule out the lift pump? Or could a faulty lift pump sent oil to the fuel filter as well as fuel to the block.
Thanks,
GB
Old 03-04-2005, 10:49 AM   #10 (permalink)
Tom S's Avatar
My Photos: (20)
No the lift pump should not do both. Time for injector o-rings.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood, 14.92 @ 89.35mph at 6000ft 368hp and 650tq corrected
Tom S is offline
