engine runs rough when cold - Diesel Forum - TheDieselStop.com
Old 10-27-2007, 10:17 PM   #1 (permalink)
My Photos: (5)
On cold mornings after i crank up and begin driving the engine almost seems like it is running out of fuel and does not rev smoothly. After it is warm it does not do it. It only does this for maybe 10 min off and on, then it quits. Thanks in advance for any input!
2012, F-350, SRW, Crew Cab, 6- speed auto, 4x4, PowerStroke 6.7L, 3:55's, black, Lariat, SWB, Ranchhand brush guard
GO DAWGS!
Pentahopepowerstroke is offline   Reply With Quote
Old 10-27-2007, 10:26 PM   #2 (permalink)
My Photos: (5)
Re: engine runs rough when cold
GO DAWGS!!!!!
GO DAWGS!
Old 10-28-2007, 08:30 AM   #3 (permalink)
It could be the normal operation of the exaust back pressure valve, that is used to help heat up the motor faster, it makes it feel like the motor is holding back....
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline   Reply With Quote
Old 10-29-2007, 03:49 PM   #4 (permalink)
My Photos: (5)
It's more like a sputter and the engine does not run smoothly when accelerating . But as soon as it a little warm it does not do it. The EBPV would be more constant and result in a hissing sound...correct?
GO DAWGS!
Old 10-29-2007, 07:22 PM   #5 (permalink)
Correct...
How old & what weight oil do you run?....
Rick.....
Old 10-29-2007, 10:59 PM   #6 (permalink)
My Photos: (5)
I change my oil every 5000 and use Delo 400 (10W-40) I still have about 2000 mi left before next change.
GO DAWGS!
Old 10-29-2007, 11:49 PM   #7 (permalink)
Erikk's Avatar
My Photos: (12)
When is the last time that you chnged your fuel filter? As the fuel is thicker when cold it may have more trouble getting past a partially clogged fuel filter...?
1996 F-350, 7.3 PSD, SRW C/C, 240k
4X4 Manuel hubs, 4.10, E4OD #2,
Michelin 285/75/16 E
Did-it-myself (Tymar style) open intake
Strait 4" turbo-back exhaust
Erikk is offline   Reply With Quote
Old 10-30-2007, 06:59 AM   #8 (permalink)
My Photos: (5)
I change it every time I change my oil.
GO DAWGS!
