Engine temp sensor Question!! - Diesel Forum - TheDieselStop.com
Old 01-16-2007, 10:56 PM   #1 (permalink)
billcare's Avatar
Does anyone know a GOOD reason why you couldn't use the stock engine temp sensor and gauge for a trans temp gauge? My plan was to put the sensor on the hot side of the trans cooler. Wanted to install a good water temp gauge anyway... Tell me if I'm Nuts....
97 PSD , Blue, Four tires!? 3" downpipe, I hate cats.
Tymar Intake 227K Aero bullet muffler
4 Hankooks, I love these tires... 3.55's
Resistor chip and new FP
Replaced so far, CPS, lift pump, Glowplugs and UVCH, VC gaskets, FPS.
Removed the stock engine fan with an electric fan from a Mercury Villager-much quieter and no problems so far.
Removed injectors and had them flowed and resealed! God gave me a new truck for about $300!
billcare is offline
Old 01-17-2007, 07:34 AM   #2 (permalink)
DZLJIM's Avatar
Re: Engine temp sensor Question!!
Not sure, but why not just spend the $60 and get the right gauge?
Black, '96, F-350, 4x4, Day Cab.
Black/Silver, '97, F-350, 4x4, CC Short Bed.
DzlJim.com for some redneck engineered projects.
DZLJIM is offline
Old 01-17-2007, 07:50 AM   #3 (permalink)
BlueMule's Avatar
My Photos: (12)
The only downfall I can see to that setup is that you still wont know what your temps actually are. Im sure there will be a few that will tell you the stock H2O temp gauge is an inaccurate piece of crap. Dont believe them untill you find out for yourself. I have both an aftermarket and stock water temp gauge. Once I learned what the letters compared to in degrees I find the stock gauge to be quite accurate, but just not as sensitive to small temp variations as the aftermarket one. I think you'll be fine as long as you run them side by side for a while and learn the scale on the NORMAL gauge.
BlueMule is offline
