Ether damage? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 02-21-2008, 12:16 AM Thread Starter
SlopeTruck's Avatar
My Photos: (29)
Ether damage?
Got a chance to buy a '96 CC 4X F350 for $3500 or less. Body is straight, running gear great, front end just gone through, 100K, AT in good condition, etc... Was also a slope truck. I'm going to look at it next week.
Guy loaned it out, glow plugs didn't start it at -35, no plug ins so friend used ether. Now runs like crap. Guy think it cracked a head. What should I look for/test to confirm that? Other ideas/thoughts as to extent of damage?
Ad said it ran rough so I figured it would be the uvcg, cps or ipr... Don't mind tearing into it, I know where I can get parts and this would give me a chance to get DIY injectors done and swapped into mine with less down time.
THANKS!
'00 Excursion Limited, V/B code springs, 35" BFG, open element intake, 4" dp+ exhaust, F350 rear swaybar, TW 4 pos. chip, FF 160 injectors.
SOLD '00 F350 Lariet CC 4X4 on 37" Iroks, 325K miles, pulled most stuff off and put on the EX.
SOLD '95 F350 CC 4X4 (ex-slope truck) flatbed on 35" BFG and H2 rims.
Play/plow truck '91 F350 on 40X17X15's, 351W, CC bobbed 3', winches front/rear, lots of DIY stuff.
SlopeTruck is offline
post #2 of 8 (permalink) Old 02-21-2008, 07:49 AM
youll need to run a compression check--sounds like might have cracked--or broke, a piston---cant use gas compression tester as it doesnt go high enough--and youll need the adaptor for the powerstroke------
94_turbo is offline
post #3 of 8 (permalink) Old 02-21-2008, 08:25 AM
hheynow's Avatar
My mechanic tried to start my truck on ether once. He never disconnected the glow plug relay. There was a big BOOM but the ether never helped get it started. Once it was finally running the truck ran fine but 3 months later I changed my Tymar air filter and noticed a black burnt area. See attached photo. The BOOM singed the inside of the filter. No more ether ever again for this truck.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #4 of 8 (permalink) Old 07-12-2008, 02:04 AM
sloate's Avatar
if you use ether you all know it could bend/brake something but even if the GPs were disconnected its hard on the rings because it cleans all the oil off the cylinder walls which will cause faster ring wear, just something i learned today...
1995
F350, CrewCab, 7.3 PSD Dyno at 390 HP, zf5, 3 in Down pipe with 5in straight pipe with stack, Tymar, DDP stage 2 injectors, Intercooled, Stole it at $2500! 400000miles! Going for 1/2 million
1989
L8000 Dump Truck, 7.8L , 6 speed Fuller, 315000miles
1964
F350, 24v 5.9 Cummins, New Nv4500, Np205, JD green paint "Built Not Bought" 0 miles,
sloate is offline
post #5 of 8 (permalink) Old 07-12-2008, 08:15 AM
I seen idi started on diesel without the glowplugs disconnected. It usually burns off one or more of the tips and embeds them into the top of your piston. This makes for one loud knocking engine. I can imagine that this can happen in a powerstroke with the option of the burnt off glow plug tip hiting and damaging the injector tip. Idi engines did have a ether port built into the air filter for an optional ether system for use in areas like alaska.
macmaniac1 is offline
post #6 of 8 (permalink) Old 07-13-2008, 09:09 AM
Just yesterday I had to replace the alternator on my F-450 and my men on the job was getting her jumped off due to batteries being dead. I went and was loading up some equipment and came back around because they were having a problem getting her started. I thought I smelled ether and low and behold I seen a ether can in one of my mens hands. I went bezerk on him. I guess he had the can in his car, because I do not buy it. He said that he had not used it yet, but I do not beleive him. I had them to let the truck sit for about a half hour and she started up and no bang. I was so mad I could not see straight. These engines will not handle it. Ether is for old detroits only!!!!!!!!!!!!!!!!!!!!
2008 F-350 SRW CC, Auto. Love It.
97 F-350 CC SRW4x4 5 speed manual South Bend Clutch. Tymar Intake, 3" Down Pipe and a Custom 4 inch Exaust. Soon to start a few other minor mods for a few more ponies.
ADDED: 95 F-450 reg. cab. 183" wheelbase, 5 speed manual, 5:13 gears. Bone Stock for now. Bought it with 67,500 miles, for $8,500.00. Has a 13ft. flat bed, with a Ramsy 9ton dump.
2008 Dodge Nitro SXT 4x4 with a six speed manual.
painter213 is offline
post #7 of 8 (permalink) Old 07-14-2008, 08:51 PM
In the WORSTscenary is less harmfull to use WD40 than ether.
96 F250, PSD, XLT, SC, SB, E40D, 2WD, 3.55, 142K.
DIY air intake and exhaust brake. Tymar Hypermax DP 3-3.5" ceramic coated; Tymar HPX; GPR switch; upgraded headlight harness; Isspro gauges; 14.7K cOOn´s mod; shim FPR; tranny cooler; CCV mod.
MX_STROKER is offline
post #8 of 8 (permalink) Old 09-12-2008, 02:46 AM
swacor's Avatar
oil
Ive used ether on mine but I waited a few to put it in and started gpr. If you unhook it it should be ok. I have growen up with diesels for 20 years and and a little shot should not hurt the head, plus dont run 15 40 when its that cold I run straight ten weight in winter.
swacor is offline
