F350 4WD Toe In Spec? - Diesel Forum - TheDieselStop.com
post #1 of 6 (permalink) Old 11-01-2010, 12:57 PM Thread Starter
I have done numerous searches and for some reason, can't find the 94 F350 4WD toe in spec. I set mine around and eighth and would like to verify this?
M1911 is offline
post #2 of 6 (permalink) Old 11-01-2010, 03:14 PM
PsRumors's Avatar
The service manual for my '97 shows .06 degrees in.
'97 SCLB 4x4, 3.55, D60 w/ TrueTrac, 6637, Banks Techni-cooler, BTS Trans, Tru-Cool 4921 Trans Cooler, 1.0 exhaust housing, no ebv, 3" DP, Straight Exhaust, E-Fuel, International WP, 203*, Gauges
PsRumors is offline
post #3 of 6 (permalink) Old 11-02-2010, 12:34 PM Thread Starter
Thanks for that, I just need to figure out how to convert .06 degrees in. to inches or millimeters.
M1911 is offline
post #4 of 6 (permalink) Old 11-02-2010, 12:57 PM
fordsforever73's Avatar
My Photos: (24)
Feedback Score: 2 reviews
I'm pretty sure when I rebuilt the solid axle in my '80, I set the toe to 1/8" and never touched it again...and that was close to 20 years ago! No tire wear issues with 35" AT's.
2005 F-350 CC, LB, 4x4, Dually, 6.0 Powerstroke, Torqueshift, 4:10 Gears. Gooseneck and rear pull hitches. "Truck Covers USA" roll up aluminum tonneau cover. Putco Boss Running Boards. Aluminum finned diff covers. Bilstein HD shocks. ProComp steering stabilizer. XRF ball joints. NC Hornet CCV mod. RCD egr delete kit. AirDog fuel system. Strictly Diesel's regulated fuel and coolant return lines kits. Amsoil oil bypass (by NUC Motorsports) and homebuilt coolant bypass kits. CFM intake elbow. ARP head studs with factory gaskets and all upgrades. FICM by Ed with Atlas 40 tune, DC Power 185 amp alternator, MBRP 304SS "Cool Dual" exhaust system. SCT Livewire tuner with pyrometer. Autometer 'A' pillar gauges (Boost/Trans temp/Pyrometer/Fuel Pressure). 850 CCA Motorcraft Batteries. Using Rotella T-6 synthetic oil. Upgraded degas tank and cap. Hayes deep aluminum trans pan. GoGo Diesel modified direct clutch solenoid. Retro Solutions HID head and fog lights. High idle mod. Jimmi-Jammers. +More.
fordsforever73 is offline
post #5 of 6 (permalink) Old 11-02-2010, 01:20 PM
My Photos: (24)
OK, so I go out to the shop to look in a factory Ford shop manual I have for a '90 F-series truck. Look up specs for F-350 4x4 monobeam and it says: +0.3 deg positive (inward) to -0.2 deg neg (outward). I take that as +0.1 deg as the nominal "Ford" spec. This is with stock tires. So, I would think if the truck is on an alignment machine, these specs (in degrees) would stay the same with any tire size. But if you are using a tape measure, and measuring in inches, toe-in specs will be different with smaller/bigger tires.
I still say, you can't go wrong with 1/8". Good luck.
post #6 of 6 (permalink) Old 11-02-2010, 02:19 PM Thread Starter
Thanks ff, I'll leaver be. It has been driving ok, but I remember when I set it, I was kind of guessing.
M1911 is offline
