They get stuck often. It's happened to me countless times. push the switch over and over and often times that'll "unstick" it.
1995 F350 7.3 PSD Turbo Crew Cab long bed with factory Regency Conversion. @197k miles. Downpipe, 3 way Superchip, Tymar intake, 35" Toyo open country tires, wheels, and high pressure fuel pump modification. Texas legal exhaust
Doesn't matter how many times you try, you can only unlock them manually. I remember on my 90 that the doors had motors that would lock up. However it would usually only affect 1 door, not all. Is there a relay or something in the wiring?
dandiesel here are somethings to check fuse number 6 and 8 in fuse box in cab fuse 20 in distribution box under hood. There is a keyless module under the dash above the fuel pedal there will be a gray plug take a paper clip bend it in a U shape and jump across it with the key in the on postion.
hope this helps
1997 F250 XLT CC PSD E4OD 4.10LS (AB CALI Truck)
3" down pipe
18k mod
DIY intake
2" leveling
egt,trans,boost,water,oil,oil temp,volts
Cat delete
1996 F250 XLT EC PSD E4OD 4.10LS (AB CALI TRUCK)135K
DIY intake
DB exhaust brake
HD trans cooler
Does the other (pass side) switch work?
I just replaced the switch on the drivers side of my 97, ford OEM 22 bucks. Same part number expect for the last letter, A and B right and left can not recall which is which right now.
I tried a while back to take the switch apart and clean it only lasted for a short time.
Rick H...
__________________ Omaha Metro Powerstroke Diesel Club
Pres Omaha Metro PSD Club Biodiesel Calculator
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp [color:"RED"] RDRCM#20 [/color]
Is it both doors that don't unlock?
My passenger one started doing this. Lock, but no unlock. Only manually. Turns out I had a wire in the plug under the kick panel corroded right off. Replaced the wire end, works perfect now.
