Factory Alarm System - Diesel Forum - TheDieselStop.com
Old 03-03-2005, 08:20 PM   #1 (permalink)
Lately the alarm system has been going off for no reason. Horn honking and lights flashing. So far it hasn't happened in the middle of the night. But with my luck it's only a matter of time. Does anybody know anything about these units? Thanks
95 F350XLT DRW,Banks Power Pack,Trans Command,K&N,97 injectors,E4OD,4.10,Banks Brake, smart lock, guages,hayden tranny cooler, 2wd
Joppy is offline
Old 03-04-2005, 07:51 AM   #2 (permalink)
ALD
Re: Factory Alarm System
Do you have the key fob for the remote entry? The panic button makes the horn blow and lights flash.
Andy
96 PSD F350 XLT Black 4X4 E4OD, NAW4, 4.10s Reg Cab, engine ser# 2115XX, stock, FPR shimmed, kitty sounds hollow, 136k, Curtis Sno Pro 3000 plow. Bilsteins front & rear, No fuel heater
97 PSD F250 XLT Black 4X4 E4OD, TDE0, 4.10s CC, d.o.b. 07/17/97, engine ser# 5476XX, 295/75/16 BFG ATs on 16 x 8s, stock, cali emissions FPR kit, adjustable oil temp, kitty just had a plugectomy, 122k, ARE bed cap, Bilsteins front & rear, no fuel heater, 2 yellow Labs
1998 VW Jetta TDi
2001 VW Beetle TDi
http://community.webshots.com/user/andyd153
ALD is offline
Old 03-04-2005, 08:18 AM   #3 (permalink)
Does the key fob still work, if you have one? I wonder if it starts acting up when the batteries get low. I had the same thing happen on an explorer and my mustang. Good luck
1996 F250 4x4 5sp shortbox, ats intercooler, DIY Tymar, 3" dp, Dual 5" stacks, South Bend Con-O clutch and SMFW. BDP Stage 1's up and running!!! my truck
TS 6 pos. chip-High idle, Economy, Tow, Jody Tipton Hot (75 hp), Diesel Power Extreme, and TWildman's "Move it or lose it" Extreme
"A man can always stand a little bit more horsepower" - Chris Ledoux
Strokerin is offline
Old 03-04-2005, 10:40 AM   #4 (permalink)
yes I have the key fob and it works like it is suppose to. maybe the battery in the fob. will replace it. thanks all.
Joppy is offline
