On the Fence with my truck
I'm thinking it might be time to get a new truck. I've got multiple rust issues on the cab, front fenders, and bed panels. I need to pull the bed to fix rotten crossmembers on it. Also, she is smoking quite a bit now. Way more than the past. I use probably about 2-3 quarts of oil every 3-4k miles between changes. Power doesn't seem off at all though. I have also noticed the end of my tail pipe looks almost wet. Is it possible that it is unburnt fuel coming out and showing at the end of the tail pipe? Also tired of the truck beating me to death with its ride. On the other side, can't afford a new truck, this one is fine for my needs at the moment. It might go another 60k fine so what am I worrying about? Any thoughts?
1996 F250 4x4 ext. cab, long bed 5 spd. 3.55ls, Tymar Intake, Tymar 4" downpipe and 4" exhaust. AIC, B&W turnoverball, EBPV brake, tranny temp gauge, boost gauge, and egt gauge. 2.5" axle drop bracket, F350 springs up front, and F350 rear axle blocks. 260k miles. RETIRED.
NEW (to me) 2005 F350 FX4 Crewcab shortbed, SRW, Lariat, auto, V10. 5600 lbs front end.
