First post...fuel heater question - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 07:50 AM   #1 (permalink)
Hello everyone!
This is my first post here. I have a 1997 F350 extended cab with the 7.3L. As far as I know, it is stock other than a K&N filter. I bought it from my wife's grandfather, and it's barely broken in with less than 78,000 on the clock...and it's a Florida truck to boot.
At any rate, as far as I can tell, I had the fuel heater in the filter bowl short out on me on Sunday (blown fuse #22). Fortunately, I was less than 1/4 mile from home when this happened. Based on info from posts here, my best bet is just to remove it from the circuit.
Now for my question: Do you guys just unplug the heater inside the bowl, or do you remove it altogether, and not replace it? It looks like it would be tough to get to the plug in the bowl without at least taking the heater loose because the plug is under the heater plate.
Also, my bowl does not drain when I flip the drain lever. Any suggestions on how to clear it?
Thanks!
Graham
Graham08 is offline
Old 11-03-2009, 08:10 AM   #2 (permalink)
Parky66's Avatar
My Photos: (5)
Hi Graham,
Welcome to the site !!!
I just disconnected my fuel heater when it went out, left it in the bowl with no ill effects thus far. As far as your drain valve not working, I would order the drain valve repair kit and go for a o-ring replacement as listed here in the stick thread... http://www.thedieselstop.com/forums/...-valve-130024/
Sounds like you have one SWEET Truck there with only 78k miles. Do yourself a favor and get rid of that K&N as soon as ya can man !!! Those things let all sort of stuff get through... Removed K&N to find......
Again welcome to the site and I'm sure you will get a lot of replies here from the experts... it has been truly a AWESOME place to learn for me.
Mike Parker - Parky66
1996 F-250 Ext Cab
Long Bed, 4X4, 7.3 PSD
(ZF5) 5-Speed Transmission
(Twildman's) 4 Position Chip
Auto Meter Cobalt Series Gauges on Full A-Pillar
Tymar Intake
(DPP) 3" Downpipe
(DPP) Catalytic Converter Delete Pipe
Lund Moon Visor
RCI 2950
Kenwood MP3 Player
Parky66 is offline
Old 11-03-2009, 08:50 AM   #3 (permalink)
Thanks for the tip on the K&N. I'll be ditching it soon. I have heard the same thing from some dirt late model engine builders, that the ring seal lasts a lot longer with a Wix or similar paper filter over a K&N.
We run K&N's on my sprint car, but the other option is nothing (no paper filter fits a Hilborn injection), so the K&N beats that hands down.
Graham08 is offline
Old 11-03-2009, 09:00 AM   #4 (permalink)
Just unplug the heater on the outside of the filter housing. Passenger side of housing IFIR it is the top plug. Hope this helps.
97 F250 Ext Cab E4OD,224K Miles.Mods.10K,Shimmed Fuel Pressure,6637 Air Filter,140Volt IDM, 3" DownPipe.
Jeep1947 is offline
Old 11-03-2009, 10:57 AM   #5 (permalink)
Supporting Member
tbeck's Avatar
Ditch the K&N, and contact Dale Isley at TYMAR Performance. You won't be dissapointed. Good filter, great service, and a stand-up guy, to boot!
'94 1/2 F250 4x4, SuperCab XLT, 5 spd, SMF w/ Valaeo clutch, 4.10 (syn. lube), Cenex Maxtron 15W40 Syn blend, manual hubs, B&W Gooseneck hitch, Toyo M-55 tires in 235/85R16, authentic Tymar intake, 4" AFE exhaust, FRP mod., SD starter, Isspro boost/pyro,digital thermometer, homebuilt exhaust brake, 170K
Last edited by tbeck; 11-03-2009 at 03:21 PM. Reason: Left ou the reason for the statement!
tbeck is online now
Old 11-03-2009, 01:33 PM   #6 (permalink)
I tried to unplug mine on the outside and the plastic started to break, so I thought before further damage it was safer to unplug inside. Remove the filter and get a pair of needle nose pliers and the wire pulls off easy inside to bowl.
As to your drain, I doubt there's anything wrong. What happens is the drain hose has air in it and not fuel. It takes a little priming to get things moving. Sometimes tapping on the fuel filter will get things moving. If this doesn't work, hook up a hose to the end of the drain valve tube, give a quick suck to the hose and be quick to put the hose in the drain pan because fuel will follow in 1/4 second.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
Old 11-03-2009, 11:27 PM   #7 (permalink)
I always drain mine with the engine running use the fuel pump pressure to blow the crap out of the line.
Jeep1947 is offline
Old 11-04-2009, 08:12 AM   #8 (permalink)
Update...
It was the fuel heater! I just unplugged it on the outside of the bowl...no problem w/plastic breaking. Replaced fuse #22, and everything is good again.
Except, I have no turn signals or hazards. I'm guessing it is the flasher.
I started the truck w/the drain open, and it blew the crap out of the line. I'll be doing this more regularly now that I know the procedure.
I'll be sticking around here. Tons of good info. Now I'm looking at doing an air filter upgrade from my K&N, and probably an exhaust (at least a down pipe).
Thanks!
Graham
Graham08 is offline
