Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 01-05-2008, 03:34 PM   #31 (permalink)
Send a message via AIM to mk3drift
Re: Fix your fuel leak from filter drain valve
could this cause the truck not to start when its warm. i noticed i have fuel in the valley i cant figure out where its coming from and i dont know if it was doing before
"liftem, fat chicks cant jump"
'96 f350 intake,4" exhaust,bully dog chip more plans after i get it to start all the time
mk3drift is offline
Old 02-04-2008, 06:55 AM   #32 (permalink)
sabir
Hi, This post is very informative, however I would like some specific information. If someone can help me then please send me a private message. Best Regards,
Sabir is offline
Old 03-03-2008, 10:41 PM   #33 (permalink)
i recently replaced the o-rings on the drain valve....picked up the three o-rings off ebay with not so accurate instructions. i had to pull the whole filter assembly from the engine to gain access to the #20 torx screws to remove the valve....after that it was easy. unfortunately it didn't fix what ever is leaking.
justin
'97 f250 ex. cab
trukpro is offline
Old 04-01-2008, 04:52 PM   #34 (permalink)
I am experiencing a fuel leak and doing searching here to be prepared on what to look for before I tear into it....when I click on the link in the first post I get a message saying I am denied access to that thread and don't have permission to view it.......any real reason for that? is this privledged information? if so, why? I have always found this forum to be a help and this seems a bit counterproductive.
97 F350 Crew Cab Powerstroke Dually-Automatic
Mods: 3" downpipe, K&N Filter
presvt is offline
Old 04-03-2008, 08:53 PM   #35 (permalink)
Jim Felix
I'm having the same problem with my '97 SDPS and with the website. Hope we get both answers.
JamesFelix is offline
Old 04-03-2008, 09:12 PM   #36 (permalink)
Is there a site that has a diagram of the fuel system to help me better understand just where this filter drain valve is located and what I'm getting into?
Great site. Helpful reading.
Old 04-10-2008, 10:08 PM   #37 (permalink)
klhansen's Avatar
My Photos: (92)
Sorry guys, the software conversion of the website messed up the original link (and lost the photos).
I just reposted the photos and linked directly to them.
Kevin
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 04-30-2008, 09:58 AM   #38 (permalink)
Great info in this thread. I have a fuel leak I need to fix.
'93 F-350 Crew Cab SRW 4X4
'97 F-350 Crew Cab SRW 4X4
Scott D is offline
Old 05-01-2008, 02:18 PM   #39 (permalink)
LunaTech's Avatar
Looks like the little green bands we use when banding calves
LunaTech is offline
Old 05-09-2008, 05:48 PM   #40 (permalink)
i have a fuel leak, it is coming out of the bottom of the fuel filter i believe... or it looks like it is at least... Could this be the same thing as what your referring to?
Drock96 is offline
Old 08-09-2008, 09:29 AM   #41 (permalink)
Unhappy I have a big puddle of fuel
I have this big puddle of fuel in the valley of the engine that runs down on the ground at the transmission or back of engine. I also have a leak back at the duel fuel tank switching valve. The rubber fuel lines look like they are special made from the factory with clamps I have never seen before so where do you get them? I am getting air in the lines that causes the truck to almost stall going up hills even with my foot to the floor. Has anyone replaced these lines back at the tank and the switching valve? Will the tanks need to be drained? I just filled both fuel tanks right before the truck started acting up so I have about 30 or more gallons of fuel on board. I have a 1995 7.3 Power Stroke.
big_dog_daddy is offline
Old 08-17-2008, 05:02 PM   #42 (permalink)
Well the verdict is in and here is what was done to fix the truck after service codes were ran. Had to replace the exhaust pressure sensor, injection control pressure, EBP & tube, ICP, IPR, bad leaking lift pump and hoses, low fuel pressure sensor and injector o-rings. Checked fuel filter and found to be like new and injector pump is good. My truck runs like a new truck and now you can actually feel the power the truck has gained and hear the turbo whistle every time you hit the foot peddle. Before the work, the turbo could not be heard and the truck had little power. Even the transmission is shifting better. I can't believe the difference the work made.
1995 white/gray Ford F-250 XLT, extended cab, long bed, 7.3 Power Stroke. Automatic Transmission with upgrades. 4" stainless steel turbo back exhaust, Bought from one owner with low miles and many aftermarket upgrades. Has original like new interior and exterior.
Big Dog Daddy
