I imagine that you guys down here in the basement are having troubles with fuel leaks like the superduty crowd is. I just posted some photos that may help out with this.
Here's some pix of a 94-97 van filter drain valve.
No, in fact, you can't even buy the o-rings separate from Ford AFAIK. They just sell the whole valve.
Any place that sells o-rings can fix you up. Viton is the preferred material, but Buna-N has been working for me for quite a while (over 1-1/2 yrs). For Viton o-rings, try www.mcmaster.com or www.oringsusa.com
[/ QUOTE ]Once I looked at the pics I saw instantly why the o rings are not sold separately. The rings serve as ball valve seats....so they are considered a part of the valve itself...Yeah, they also seal the valve body to the filter, but....
Now you see why it's is best to use viton...as they are seats, then they experience wear whenever you operate the valve, unlike a static seal.
95 F-350 DRW extended cab Dixie Custom, 180K troublefree miles, straight pipes, no other mods....Yet.
ok i know where the 2 torx tip screws are and i have my o-rings in hand. my question is do i have to remove my filter bowl or can i somehow get to the 2 screws for removing and installing. it looks tight because it is at the bottom of the bowl. thanks
2000 excursion superchips progamer,(ole ladies ride) no fuel milage increase but the power is there.
2000 f250 4x4,hypertech tuner ,no kitty,4in exhaust turbo back , air raid filter
97 f350 psd, c/c, 4x4,3.55ls, 285/75 goodyear MT/R's
shimmed w/ calif. kit, 10k mod, ported snorkel,hypermax downpipe,ps2000 propane
45hp superchip,pcm code TDE1, TEXAS TROPHY HUNTERS decal!!
looking for hunting opportunities in the north mississippi area or s/w tennessee, deer and hogs , let the littles ones walk
Sorry I can't tell you, as I've never done the job on an OBS truck, just borrowed the filter bowl from a buddy to take the pix.
There's one sure way to find out, and that's dig in and try it.
Post what you find out here, so other folks will know.
If you got super small extra long fingers and they can bend in several areas at once then you might be able to but if not,take the rubber line lose on back of filter can to pump,take lose the line on the right side of the filter can,look in back of filter at very bottom youll see two metric bolts holding it down,take out,now youll be able to move filter can around some,not much but enough to get a t15 torx socket on,break lose then use fingers to turn socket till out a bit,then use just fingers to completly remove little torx screws,the handle comes off with it once its lowered alittle,,the newer valves have 4 torx screws and want work on older 94s,take your time,if you drop anything youll need a small magnet to fish it out.
My 95 Ps 7.3 is leaking bad!! It began stalling now and then. Then I noticed stains on the driveway, thought tranny was leaking, it was diesel fuel. Its deep enuff in the block valley to splash with you fingers.... A mech has removed all but the filer housing and can't find the leak yet... what do you think, could this post be about what is wrong ???
'95 Crew Diesel Dually 7.3 automatic 147k 12/02/05 no cat, bigger DP I was told. "Don't put sides on your Shop, or the Ole Lady will want to store Furniture in it"
I once had a leak so bad in my 97' that it took the whole rear tank and half of the front to run 10 miles! When I took it apart, the fuel housing must have been a bad casting..... there was a dime sized hole in the bottom of it! Took it to a welder and had him tig the hole shut since a new housing was over $300. So far so good.
__________________ NEW TRUCK: 2002 F350 CC,Short Bed, Dually w/ 7.3L, Air Raid intake, 2 gauge pod (for now). Have all winter to get her ready to tow the toy hauler.
OLD TRUCK:97' F250 4x4 crew cab. 4:10 gears,High Idle mod, Dana 60 conversion using 3"SKY RSK w/03' SD springs and 3 3/4" rear blocks to level. Tymar, Issopro gauges on 3 gauge pod, 3" down pipe, shimmed FPR and DP tuner 6 pos. chip (12-13-07). http://community.webshots.com/user/amberjax
