Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 08-12-2007, 02:17 AM   #16 (permalink)
Re: Fix your fuel leak from filter drain valve
I just replaced mine on my 96 but I think my filter housing might be leaking too (cracked?). BTW you can get the screws out with the filter in place. I got this little racheting deal from Harbor Frieght. You squeez the handle and it turns the bit comes in a box with all the bits. Mine was philips but the kit has torx bits also. Was real easy with that tool ($14).
1996 F350 XLT CC LB 4x4 120K, E40D
Tymar Intake, Magnaflow 4" SS Exaust, Edge Evo, FPR Shim, SKY RSK w/SD vcodes, Bilsteins, Velvet Ride Shackles
TRUCK PICS
2004 Outlander Max 400HO (mine)
2004 Rally 200 (hers)
2004 Grizzly 80 (sons)
fitzgood is offline
Old 08-27-2007, 05:08 AM   #17 (permalink)
McMaster-Carr tends to sell o-rings in packs of 25 or 100. There has been a vendor on ebay selling them in individual service packs for the PSD drain valves. Or just buy them and share them with 24 of your friends as they are fairly cheap (viton ones) from McMaster-Carr.
Dave Murakami 97 F-250 XLT Supercab PSD OffRoad, Bilsteins, Warn manuals, Rhinoliner, Bridgestone 285's, molded steps, smittybilt grille guard w/frame braces, Cibie driving lights, power rear window, Sony CD changer w/infinitys+basslink subwoofer, Tekonsha Prodigy, Snugtop, Reunel stainless steel rear bumper w/Warn HS9500 winch/PIAA backup lights, TFI, 7500lbs, 14.508 1/4, 408 rwhp/#2only, banks powerpack, gutted ebpv, 4" duals, map pressure regulator, JSidm, BTS, maddog stage II ABs, Bean's fuel system, Terminator, dieselpower tri-chip, tymared, black intake, non-fluttering Isspro EVs, almost stock!
masami is offline
Old 08-28-2007, 05:05 PM   #18 (permalink)
hheynow's Avatar
A great product to trace fuel leaks is Spectroline Gas-Glo p/n 1U-5574. It's a fluorescent dye designed to be poured into the tank and fluoresces under black light at the point of the leaks.
1997 F-350 PSD RC LB 4WD E4OD - Plant Drive SVO kit
1984 Mercedes Euro 300D NA - Custom two-tank SVO
Using WVO and biodiesel since May 2006
hheynow is offline
Old 09-05-2007, 07:48 PM   #19 (permalink)
Send a message via Yahoo to JoshuaLee
Mines leaking again go figure... Damn pile of junk Ford... Anybody have a place that sells these o-rings? These guys around here are complete idiots and don't know what a part is unless their little computer tells them what it is.. I will pay postage if somebody can get me the correct o-rings to do the whole housing...Thanks!
JoshuaLee is offline
Old 09-06-2007, 09:30 PM   #20 (permalink)
??? Nobody
Does anybody else see a problem with some of the parts on these Ford trucks? It seems as if they were engineered to break...
Old 09-07-2007, 03:17 AM   #21 (permalink)
klhansen's Avatar
My Photos: (107)
Here's some part # info from This website
Fuel Filter Housing Reseal Kit
(International) 1823645C91 (94-95) (Part # inside Ford packaging, bad per IH)
(Ford) F6TZ-9157-BA (96-97)
(Ford) F5TZ-9157-A (94-95)
Includes:
(Ford) F4TZ-9C064-A O-Ring Water in Fuel Probe
(Ford) F4TZ-9C065-A O-Ring Heater Connector
Not Available (International) 1823565-C1 O-Ring Water Drain Valve
Not Available (International) 1823635-C1 O-Ring Orifice Vent
Not Available (International) 1823644-C1 O-Ring Pressure Regulator Filter
Not Available (International) 1823655-C1 Ball, FPR Check Valve
Not Available (International) 1823662-C1 Gasket, Element
Not Available (International) 1824476-C1 O-Ring, Prescreen Bowl
99.5 F250 PSD Supercab LB 4x4, 6spd, 3.73LS, Boost & pyro gauges, Swamps S175/146 injectors, Jody's 80 HP Econo PCM (classic version), AIS, coolant filter w/"hokum" bracket, regulated return, heated mirror mod, lighted cupholder, Marinco heater plug-in.
Hard or no-start? Check here
klhansen is offline
Old 10-09-2007, 12:29 AM   #22 (permalink)
I found this http://cgi.ebay.com/ebaymotors/Ford-Powe...1QQcmdZViewItem on ebay. Seller says that they fit 99+. Will they fit OBS?
95 f250 psd reg cab XLT 4x4 5sp 4:10 188k
diy tymar, big exhaust, 4 pos chip burnt by bdp, carbon fiber gauges, luk smfw
bean's stage I's
new ride: 02-99 f350 srw cc lb 4x4 6sp 3.73 stock, previous owner installed some kind of 10k, or 18k mod, true milage unknown
1064RG is offline
Old 10-09-2007, 01:11 AM   #23 (permalink)
I answered my own ? w/ a little more research. And found a kit that had the little oring in it. The obs needs the little one, and the sd's don't.
bean's stage I's
1064RG is offline
Old 10-25-2007, 12:26 AM   #24 (permalink)
Hey. I have a 1996 Ford F350 7.3 Power-Stroke. I have diesel puddled on top of my engine and disel dripping down on the trans and starter. Is this what you are referring to? HELP...
jtownes14
jtownes14 is offline
Old 10-26-2007, 06:33 PM   #25 (permalink)
I just talked with the parts dept with my local Ford dealer. Said they sell a seal kit for the valve for ONLY $36!!! I ordered the o-rings from McMaster-Carr....1 package of 25 lists for under $6....a real no-brainer.
fsj cowboy is offline
Old 11-03-2007, 06:32 PM   #26 (permalink)
I have a 95 f350 leaking from the water in fuel probe, or the heater connector. What ever the one with the single red wire going in is. Does anyone know what the O-ring size is for that fitting? Ford wants $46.00 for a reseal kit for the fuel bowl. I bought 20 ea. viton #202 and #013 at a local seal wearhouse for $5.00, & would like to purchase the rest of the seals from the same place. I just need sizes.
1995 F350 4x4
rollernose is offline
Old 11-09-2007, 12:45 PM   #27 (permalink)
Send a message via AIM to NWsurfer
Hey Rollernose, I'm having the same problem. Mine is coming from the same spot (red wire going in at the top of the fuel bowl) and when I looked up replacement o-rings the website said that the O-ring will not stop the leak and the whole sensor had to be replaced...
http://www.dieselorings.com/index.ph...&cat=3&group=2
Anybody else have any other suggestions or similar experience?
thanks
NWsurfer is offline
Old 11-10-2007, 01:34 AM   #28 (permalink)
Ok, I stopped by the local diesel mechanic and bought a Water In Fuel sensor. The problem with it has nothing to do with orings... it is the sensor itself. 60 bucks and a crescent wrench and it is fixed.
NWsurfer is offline
Old 12-20-2007, 01:49 AM   #29 (permalink)
A quarter inch thumb wheel rathcet works really well with a torks bit...thin k it s a#10 but not positive. The seals can be done without removing the bowl-even with descent sizt hands!
Mark
1 PSD 4x4 Custom Tow Vehicle-the 550
1 PSD 4x4 SUV-the X
2 PSD 4x4 Duellies-F350&F250HD
42' HillsBoro 23K Dbl Duellie Goose
32' Open Triaxle Dove Tail
34-5Y Prowler LSI Fiver Loaded with Xtra Stuff
SuperDutyFiver is offline
Old 12-26-2007, 12:18 PM   #30 (permalink)
there is someone selling these on Ebay and it includes the small oring for our year model for $3.00 not shipping.
'95 F-350 4X4, Manual Trans, 35"Procomp All Terrain, 314,000 miles, removed muffler, Superwinch manual hubs, 4.10 Gears, Rancho 5000 shocks, homemade air filter
jdmorris76 is offline
