Go Back   Diesel Forum - The Diesel Stop.com > Ford Diesels > Power Strokes 1994-1997 General
Old 10-04-2008, 07:37 PM   #46 (permalink)
Send a message via Yahoo to boozer88
I have a 1997 7.3 powerstroke that is still leaking. I replaced the lift pump that was leaking. Now I found a leak that is leaking from the sensor (??) that gauges if there is water in the fuel, on the fuel cannister. Can I just fix that or just replace the whole cannister??? Thx!!
boozer88 is offline
Old 10-04-2008, 07:54 PM   #47 (permalink)
Supporting Member
bugman's Avatar
My Photos: (16)
You will get more and faster help if you post down in the regular forums. As far as the leak yes you can replace the sensor or if you would like just remove it and put a pipe plug in its place. If you plug it off just remember to drain the housing every now and then to keep water out of the injectors.
Jim
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-20-2008, 02:45 AM   #48 (permalink)
Can the drain valve pull air, but not leak any fuel??? Truck starts then dies by loosing fuel pressure.
oldrebuiltdodge is offline
Old 02-02-2009, 12:03 AM   #49 (permalink)
MustangMatt96GT's Avatar
Is this the leak off of the back of the engine coming off the bellhousing/starter area?
Thanks... only happens when cold
MustangMatt96GT is offline
Old 02-09-2009, 06:19 PM   #50 (permalink)
mcr96's Avatar
Mine just started leaking the other day in the same area, just looked at valley and don't see any puddling ..... is it still the bowl drain "O" rings??
Mark
1996 PSD F250 XLT 4x4 Crew/Shortbox A/T 4:10's BFG/KO's 285/75x16, Bilstein's, DPP Down Pipe, Torque Power Module, Bel 615 Remote - Bright Red
mcr96 is offline
Old 03-23-2009, 12:10 AM   #51 (permalink)
CVB Fireman's Avatar
Arrow
Originally Posted by musstag View Post
My 95 Ps 7.3 is leaking bad!! It began stalling now and then. Then I noticed stains on the driveway, thought tranny was leaking, it was diesel fuel. Its deep enuff in the block valley to splash with you fingers.... A mech has removed all but the filer housing and can't find the leak yet... what do you think, could this post be about what is wrong ???
yess i have the same problem if you figure it out please let me know i just replaced all the hose lines. and it seems it only leaks when it wants to
f-350 4 door long bed. 6 speed. 5 inch stacks. 9 inch lift. 40 inch Ground Hogs. custom Front and rear bumpers with 10,000 Warn WincheSSSSSS.K&N TW chip, stage 1s, IDM mod, exhaust brake. limo tint. peterbilt cab lights. dvd screen 2 shallow fosgate 12s (sick!!) and everything else you can think of. damn ive spent way to much money on this truck.
Waller
CVB Fireman is offline
Old 10-01-2009, 03:18 PM   #52 (permalink)
Guys, don't forget about the fuel pump... it has a weep hole in the side of it and when it is bad, it can also leak!!!
Gary
cobra428 is offline
