floorboard vibrations - Diesel Forum - TheDieselStop.com
Old 07-05-2007, 01:09 AM   #1 (permalink)
jetflyr's Avatar
Hello all. I have a pretty good vibration going on in my floorboard. I start to get it at around 55mph, and it is VERY pronounced at 60MPH +. If I really step on it, I can feel it too. But with just normal accelerating (for me), I get at the speeds above. I have had the front shaft u joints replaced. All of which I can be greased now. Transfer case has good fluid quantity. I had the guy check the rear shaft too, and it was fine. Would the front wheel bearings do this? There may be a loud hum as I feel the vibration. I know I have a ripped boot on the drivers side outer tie rod end, and I have to keep greasing it. Perhaps this may be an issue. Though I do not feel anything in the steering. It is all under my feet. Any ideas? Has anyone had anything like this? Thanks, TOM
'97 F350, Crewcab, 7.3 Turbodiesel 4x4 off road package, Automatic transmission
jetflyr is offline
Old 07-05-2007, 06:24 AM   #2 (permalink)
Re: floorboard vibrations
After a drive check your wheels for heat,could be a dragging brake or a worn out bearing.If you have a clutch your flywheel could be going bad.If you have an after market DP,it could be rubbing the body.
97 F-250 PSD 4wd 5spd 4.10 SCLB, D60, Tymar intake, 3"dp, EBPV gut, Boost/Pyro gauges, SBC Con-O, Stancor 586-902 GPR, Royal Purple gear and tranny oils
'87 Tbird TC Auto
'87 Tbird TC 5sp
clem is offline
Old 07-05-2007, 06:05 PM   #3 (permalink)
I was jacking around w/ my exhaust last weekend and didnt know the dp had twisted into the firewall/floorboard transition and had a vibration. Get your truck up the speed at which it vibrates the worst and then engage the clutch/slide into neutral, if the vibe goes away instantly then its in the driveline.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
94strokerace is offline
