Just received recall on the speed deactivation switch in the mail today, although I had already replaced mine back in 05 because mine was leaking.
the letter went on to say that if repair was already made you could get a refund with a receipt only.(saved mine, waiting for recall!) also said until repair is made don't park your truck in a garage (gasp) keep a distance from other structures! anyone else already replace theirs?
purchased new this 1996 powerstroke 4 door dually 5 speed "272k" zf-5 speed
luk smf clutch kit,open air element, dppi 3" downpipe
wifes truck 2000 ford f150 ext. cab 4x4 5.4l 72k
ford 1900 tractor 3 cyl. diesel
1995 sooner dynasty horse trailer 4 horse w/ living quarters
john deere model l manure spreader in near pristine condition
yup, had to replace mine early this summer..........submitted my invoice to the dealer this week...... they said had to go thru so likely won't get the refund for a while. they were not prepared to do anything directly. i also know the service manager....so i guess that is the process.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
says : "
[FONT='Arial','sans-serif']Ford will not allow me to process the claim from a parts invoice.[/FONT]
[FONT='Arial','sans-serif']We would need to perform the recall in order to close the recall. A refund is not possible.[/FONT]
[FONT='Arial','sans-serif']Sorry."[/FONT]
[FONT='Arial','sans-serif']so if you had to fix it your self you are SOL on the refund.........[/FONT]
[FONT='Arial','sans-serif']Any one else get this reply?[/FONT]
SD STARTER
just un plug it intill you get the new one my GF 2001 was leaking and had taken out the fuse. so just to be safe I un-pluged it and told her to call for a appointment for the recall.
97 F-250HD Super Cab 4X4 E4OD, 3.55 gears, swamps 238'/80s & SWAMPS Chip,Beans D-66 Turbo, Adrenaline HPOP & Reservoir Filter, BTS,TSM Disk Rear Brakes,DIY Electric Fuel system,DIY Air Filter,Auto Meter Dash Mounted Gauges: Trans Temp, Boost, EGT, Oil Temp, Oil Pressure.Water Temp,Fuel Pressure Gauges,3 Inch Intake plenums, 4 inch MBRP, Intercooled, CCV mod.
294,000 Miles and still going Strong.
I just took mine in to a dealer today(shudder). They changed out one pigtail with another that has two fuses built into it. The whole assembly is already put together. They unplug the old one and install the new one. I took five minutes to do and another 10 minutes for them to complete the "no charge" paperwork.
I did call a few different dealers to make sure I could get the fix done while I waited. One dealer extimated 2 hours to complete and another was 1.5 hours. I understand Ford has been doing them on other models for some time and our trucks were recently added on the ever expanding list.
1997 F-350XLT CrewCab,4x4,7.3L Diesel,Auto,California Truck,Roll-a-long package,85K miles
Reason: spelling
It replaces the wire harness that plugs into the master brake cylinder with a harness that has a fuse attached to it. The problems that they were having was the switch on the end of the brake cylinder would leak brake fluid down onto the wire insulation witch would destroy the insulation short out and cause a fire. There were quite a few F150 that went up in smoke along with the garage or carport that it was parked in.
Yea, look at CNN. They were "lucky" enough to "happen" to have a camera rolling and shot live video of an F150 fire a couple years ago. I'm still debating how brake fluid which does "NOT BURN" coupled with a couple wires shorting causes a fire with flames 125ft in the air? It's the news though and they would not fabricate this balony? Sure they would and did. A F150 on fire regardless of the cause does not have flames 125ft in the air. Bull**** and you can all believe it if you want. If the wires smoldered and started fire you might have 3ft of fire "if" the fire was fueled with gas nearby. Diesel does not burn, brake fluid does not burn, wires are mandated flameproof and do not burn, so chances are less than 1 in 120 trillion of a fire. So hide the women and children and park the trucks out in the Yukon territory for gods sake and don't start a fire please.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
I personally haven't seen a diesel truck with any fire problem, somebody on here said that their cousins step dads, ex-wifes fourth son had one catch of fire but I doubt it. All that I could figure on the gas trucks was that after the fluid destroyed the insulation and the wires shorted out (since on the gas trucks the power does not shut off with the key) it caused problems down stream of the actual problem. The big problem is that after a engine fire it is really hard to pinpoint just where it started. It just looks like a barrel of burnt copper wire.
When I was in high school my 71 Datsun pick up had electrical issues. It had a screw in fitting in the brake line by the firewall, with two wires comming off it. One day the wires shorted, and burned through the fitting, and the brake fluid caught fire and shot a flame 3 feet in the air hitting the open hood. It continued because I tried grabbing the wires and breaking them, all I did was burn my hand. When the fuid ran out the fire died.
Are you kidding me? lol I just about crapped my pants laughing.
Go pour diesel on an open flame and see how it doesn't burn.
2003 F350 crew cab 4x4 Bone Stock.
RIP, For now. Left in a field in Wyoming.
96 7.3 f250 4x4 ext cab , longbed,3" downpipe to a test pipe, Gutted ebpv, tw 4chip, stage 1 injectors,Stealth oil pump,Electric fans. shimmed fpr . 19 mpg in economy mode 8mpg in extreme mode. 281,117 miles as of 11-30-11.
Try lighting it with a match or lighter - can't do it. Guys at the truck repair shop I used to supervise in didn't believe me so we put a puddle on the ground and they could not light it. I have never tried pouring it on an existing flame, though.
They did not try a cutting torch, though (here, hold my beer and watch this)
Gasoline, on the other hand....
Dave / Believer45
__________________ THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
