FORD - No Start - Page 10 - Diesel Forum - TheDieselStop.com
post #136 of 184 (permalink) Old 07-19-2005, 10:30 AM Thread Starter
Re: FORD - No Start
Here is a photo of the inside of the IDM off of the 1996 Ford F-250 we have been wrestling with.
that Capacitor is a Radio Shack item...the transformer...Ummmm I donno.
Photo of the IDM
1996 F-250 PSD CREW Cab 4x4 short box
1992 F-350 7.3 CREW Cab Dually Long Box
If ye love wealth better than liberty, the tranquility of servitude better than the animating contest of freedom, go home from us in peace. We ask not your counsels or arms. Crouch down and lick the hands which feed you. May your chains set lightly upon you, and may posterity forget that ye were our countrymen.
-- Samuel Adams, speech at the Philadelphia State House, August 1, 1776.
KrisH is offline
post #137 of 184 (permalink) Old 07-19-2005, 11:18 AM
Re: FORD - No Start
Kris, is oil still comming out aroung that injector? You could be losing just enough pressure that it won't catch.
Partsman is offline
post #138 of 184 (permalink) Old 07-19-2005, 12:37 PM Thread Starter
Re: FORD - No Start
I think that oil I seen was there all along, laying in a low area on the cylinder head down hill from the injector. Still possible it needs o-rings though.
But at the moment, that gully wash of fuel running off the back of the intake valley has got to be dealt with.
KrisH is offline
post #139 of 184 (permalink) Old 07-19-2005, 05:05 PM Thread Starter
Re: FORD - No Start
I've had it with this truck...I just went outside again to turn it over some more thinking all the air had not worked out yet (I got an O-ring from a local parts store for the FPR bowl seal)...Hit the key for 15-20 seconds and the starter continued trying to start the engine after I let off the key...I finally had to run up front and yank the battery cables off to keep the truck from burning up...smoke boiling from the starter.
Kris
KrisH is offline
post #140 of 184 (permalink) Old 07-19-2005, 05:10 PM
Re: FORD - No Start
Thats caused by your batteries geing low. It welds the soleniod contacts together on the fender. Give it a good wack with a screwdriver handle and charge the batteries.
Partsman is offline
post #141 of 184 (permalink) Old 07-19-2005, 08:02 PM
Re: FORD - No Start
partsman----and replace the starter-- [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
94_turbo is offline
post #142 of 184 (permalink) Old 07-19-2005, 08:31 PM Thread Starter
Re: FORD - No Start
I smacked it several times with a pair of pliers thinking that would work before going after the cables. When I hit the starter the batteries were at 12.6 volts (full charge) and had 13.8 volts @ 30 amps being pumped into them.
KrisH is offline
post #143 of 184 (permalink) Old 07-19-2005, 08:38 PM Thread Starter
Re: FORD - No Start
I'm really thrilled about taking that starter out again too. Especially that one click at a time ratchet top bolt.
I did not mention it before but the solonoid I replaced was installed with a pair of rounded out phillips round head machine screws and lock-tite. Had to take the whole mess out to have room to get the screws out by cutting a slot in them.
KrisH is offline
post #144 of 184 (permalink) Old 07-19-2005, 08:45 PM
Re: FORD - No Start
Kris, been a month now, you ready to sell it yet?
Rick H...
Pres Omaha Metro PSD Club
HIS
96 F250 4x4 auto super cab.
TS 4 Pos Chip, addaLeaf, Boss 8'-6" plow, , DIY AIC, Tymar DP, gutted EBPV, JS IDM, Tymar Intake, 4" Open exhaust, trio a-pillar gauges + 6 overhead gauges. TruCool 4590 Tran Cooler. On board air with dual horns. 4 corner strobes. AC mod with Twist, ISSPro Turbo Temp Monitor, Power Pedel mod, turbo ped mod, Warn Lock-outs, Swamps 175/173 99 IC & GTS Pipe Kit,Snow Performance Water/Meth inj (NOT hooked up!), chicken to use it!
Garmin GPS,Toughbook Laptop, All Mode Ham Radio.
HERS
97 F250 CC SWB 100% stock and going to stay that way! I lied, Shimmed, Tymar Intake. I lied again, kat dead! More lies.. 3" DP, Gutted EBPV, Turbo Pedistal Mod. Dyno'd 263 hp
[color:"RED"] RDRCM#20 [/color]
RickHredf250 is offline
post #145 of 184 (permalink) Old 07-19-2005, 08:46 PM
Re: FORD - No Start
It's definitely caused by low batteries. I work on these things all the time and i've seen it happen several times......
Starr
PS What you need is a proper scan tool. In my humble opinion,, other than the normal obvious stuff it seems like to me these things are impossible to work on without a scan tool capable of reading PIDS and doing functional tests. Try to see if you can find a snap-on scanner to use.
'02 F-250, Lariat, 4x4, 7.3L, Crew Cab Short Bed, 98k
OLD TRUCKS
'97 F-350, 4x4, PSD, XLT, 5spd. w/brass rings, LUK Cerametallic Clutch, Crew Cab, 219k, LS4.10's, BFG 35x12.5 A/T's, Front Leveling kit, Three ISSPRO Guages mounted on the A-pillar, Hypermax Thermal Coated Downpipe, 4" Strait pipe Exhaust, Gutted EBPV, Diesel Power (Bill's) 4 Position Flip Chip, Tymar Intake, Swamp's 175/146's, Late Model HPOP, Ford AIC, AMSOIL Modifications courtesy of STARR SERVICE LLC
'97 F-350, 4x4, PSD, XLT, 5spd., LUK Clutch, Crew Cab, 234k, 4.10's, Reading Spacemaster Utility Body
'04 F-250, 4x4, 6.0L PSD, Crew Cab Short Bed
PowerstrokeStarr is offline
post #146 of 184 (permalink) Old 07-20-2005, 09:30 PM
My Photos: (16)
Re: FORD - No Start
Sorry to say this, but it sounds like you had one simple problem that turned into many other problems due to bad diagnostics. Don't get mad at the truck for that.
Hope you get it fixed. Charge the batteries up and see what it does.
Tobin
2006 Dodge 2500 4x4 quad cab longbed 48RE SLT 5.9 Cummins, Smarty, DiPricol guages
Tobin LaBorde is offline
post #147 of 184 (permalink) Old 07-21-2005, 01:19 AM Thread Starter
Re: FORD - No Start
Seen, read, does not merit a response.
Tobin
KrisH is offline
post #148 of 184 (permalink) Old 07-21-2005, 10:07 AM Thread Starter
Re: FORD - No Start
As it turns out, nothing wrong with the fender solonoid. The replacement solonoid on the starter was bad out of the box. Suspected this due to this particular gremlin coming to life immediately after it's installation. Worn starter armature may have also caused this, and yes perhaps the batteries too...But most likley a combination.
Action taken: New Starter, Starter solonoid, and batteries installed. One battery tested bad both replaced, fender solonoid on order from advanced auto parts for good measure.
Apparently the fuel leak on the FPR to bowl seal has been dealt with. No more fuel flow off the valley. While I had the FPR off this time I also yanked the snap ring on the bottom and pulled that apart. The brillo filter was clogged, pulled out, and cleaned. getting that O-ring on the lower plate back in place was fun.
The truck is now back to it's first improvement...turns over, fires, but does not start. Brownish black smoke out the tail pipes. Checked the glow plugs on the passengers side when I had that apart and they were good. .08 ohms if I remember correct...Not much but enough to indicate that they were not an open circuit. Guess I need to yank the drivers side again and check those.
KrisH is offline
post #149 of 184 (permalink) Old 07-21-2005, 10:15 AM
Re: FORD - No Start
your getting there kris--be just like the terminator--never quit--truck might think its the boss--- [img]/ubbthreads/images/graemlins/biggrin.gif[/img] [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
94_turbo is offline
post #150 of 184 (permalink) Old 07-21-2005, 10:23 AM Thread Starter
Re: FORD - No Start
No vehicle has EVER beaten me. You should have heard me rant and rave when I was first learning the finer points of 68-81, 82, and 84-96 corvettes years back. I could have sold comedy tapes. [img]/ubbthreads/images/graemlins/biggrin.gif[/img]
KrisH is offline
