FRONT DOOR SPEAKER SIZE? - Diesel Forum - TheDieselStop.com
post #1 of 8 (permalink) Old 03-12-2006, 04:03 PM Thread Starter
GTstangs's Avatar
need to replace front door speaker,looking good price to?
thanks
craig
1999 F350 4x4 auto,hypermax gauges,F5 DP-TUNER CHIP hi-idle 80e 100p 140ex, Tymar Intake, magnaflow 5" exhust,35x12.5x16.5 tires 4inch pro comp lift 160k miles
pic
GTstangs is offline
post #2 of 8 (permalink) Old 03-12-2006, 04:57 PM
BigRed CC Dually's Avatar
My Photos: (9)
Re: FRONT DOOR SPEAKER SIZE?
Pioneer TS-A1671R 6 1/2" from Best Buy, Circuit City, or even Wal-Mart are good speakers. Check the size and model numbers in my sig.
Rick:Red 97 F350 CC DRW 4.10/LS E4OD, 28,000GVW trans cooler w/170F thermostat, remote ATF filter, Mobil 1 ATF, Sonnax valve & Tricum springs, Tymar Hi Performance Open Air Intake System W/Donaldson B085011 filter, IH water pump w/integrated coolant filter, BD downpipe & BD 4" cat back exhaust, "SWAMPED", Tymar HX mod, Tymar/Bill's 4 posn. "flip-chip" (this bad boy rocks), Isspro EV gages in 3 hole PITA Pod, "Harpooned" Fuel tanks, Bilstein shocks, Gutted EBPV, Alpine CDA-9825 head unit, Pioneer TS-A1671R 6 1/2" 220W Front, Pioneer TS-A6880R 6"X8" 240W rear, FOKISD member, Beavercreek, Ohio (near Dayton)
BigRed CC Dually is offline
post #3 of 8 (permalink) Old 03-12-2006, 04:58 PM Thread Starter
GTstangs's Avatar
thanks big
pic
GTstangs is offline
post #4 of 8 (permalink) Old 03-12-2006, 05:00 PM
My Photos: (9)
You're welcome, It's my pleasure.
post #5 of 8 (permalink) Old 03-12-2006, 06:28 PM
My Photos: (61)
I replaced mine with 6 1/2" (junk so I would not recommend my brand, they are waiting replacement again with something to match my Pioneer 3 ways in the back) and had to do a little modification to the cutouts in the door itself. The door panel was fine, you can't even tell anything was done unless you remove the panel and know what you are looking at.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS
, LUK clutch, homemade
, open element
, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
post #6 of 8 (permalink) Old 03-12-2006, 07:03 PM
Big Red,
I like your truck...looks kinda like mine!
Bright White 1997 F-350 XLT Crew Cab Duallie, This is a late-build (11/97) truck and one of the last of the "real" ones! 7.3 Power Stroke, E4OD, 4.10 Limited Slip, Alcoas, 5-inch turbo-back system, 42,000 original miles and every option you could think of. I love this truck...absolutely the baddest '97 on the planet...I get at least two offers to buy it every time I drive anywhere.
duallie is offline
post #7 of 8 (permalink) Old 03-13-2006, 07:54 AM
My Photos: (9)
1997F350Duallie, thanks, I'm sure I'd like your too then [img]/ubbthreads/images/graemlins/cool.gif[/img]
GTstangs, the Pioneer TS-A1671R 6 1/2" 220W speakers will bolt right in with no modifications needed (all the Pioneer 6 1/2" should). You simply have to turn them in the hole to position the pre-drilled holes in the speaker to align with the factory mounting holes. I would recommend going to Best Buy and getting a pair of speaker harnesses, you simply "plug and play" with the wiring that way with no chance of getting the polarity wrong. They were only $5.00 or so if I recall correctly.
post #8 of 8 (permalink) Old 03-13-2006, 06:48 PM
6.5" work fine. Stock is 5 1/4". Huge difference in sound quality when I put in some pioneer 3way 180watt(max) speakers. Can't wait to put some good quality 6x9s in the rear. It was amazing how much sound I was actually missing cause the speakers weren't good enough.
'97 F350 PSD E4OD CC 4x4
265/75/16, BB shim=73psi, Open Element, 10K with switch on dash, IDM mod, 30K Hayden tranny cooler, 1.0 exhaust housing, 3" downpipe, 4" straight pipe, the usual gauges, Bullydog 6 position chip (five of them work
Tankota is offline
