Front end not level - Diesel Forum - TheDieselStop.com
Old 11-10-2009, 06:12 AM   #1 (permalink)
Front end not level
AS the stated above, I have a problem wit the front end of the truck not sitting level ..... If you look at the front of the truck on level ground the left side (passenger) look likes it sits about 1 or so inches lower than the right side. I looked under the truck at the space between the the springs and the spring bumper on top of the axle and it looks to be about 1 inch closer than the driver side is. With that being said i put new leaf springs under the front about 1 year ago and still no help in correcting the problem. It seams to drive straight down the road. I also checked the bushing that goes between the bolt that lets the axles move independent of each other (it sits under the front of the oil pan) that looks fine as well. all the body mount bolts to the frame are fine and not missing as well. The truck is not lifted or never has been. ITs all stock with 240K on it. The tires dont seem to wear funny. I just had them rotated about 5K ago because they were showing some wear compared to the back tires.
Could it be the ball joints are bad. I had it aligned 10K ago at the ford dealer. The truck has been this way since i purchased it with 202K on it. It has never been wrecked that I know of. Im lost on this one guys so any help sent my way would help out alot.
dooboz is offline
Old 11-10-2009, 07:32 AM   #2 (permalink)
speeddemon31176's Avatar
Send a message via AIM to speeddemon31176 Send a message via Yahoo to speeddemon31176
Is it a 250 or 350? That would help an awful lot in diagnosing the issue.
97 F-350 XLT CCLB 4X4,PSD
Gauges(boost/pyro) on triple pillar pod
CAI
IDM mod
4" DE turbo back catless exhaust
TS 6 pos. Chip
3" PA Body lift
ES body and suspension bushings/mounts
Extreme duty trans w/billet triple disc converter
B&M deep pan
Hayden "DAWG" trans cooler
Adrenaline HPOP
stage II's, D66, then custom tunes.
speeddemon31176 is offline
Old 11-10-2009, 08:13 PM   #3 (permalink)
sorry i didnt say that is a 1997 f-250 extended cab 4x4
dooboz is offline
Old 11-10-2009, 08:49 PM   #4 (permalink)
pjwoolw's Avatar
My Photos: (5)
Only thing that comes to mind would be the front spring hanger. I do find it odd the condition wasn't noted when it was aligned. In fact I'm surprised the dealer did the alignment at all if there was that much of a difference. Possibly a different / wrong hanger on one side or the other. Pic?
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-10-2009, 09:51 PM   #5 (permalink)
i had the exact same problem on my old f-250. check the bushing on the front of the leafs. the one between the frame.
-SEMPER FIDELIS-
1997 F-350 4x4 ,XLT ,LB, SRW, S5-42 5 spd, 4.10, 125,000 mi.
- Dp tuner , RDS stg 1's,D66, T444E pedestal, Autometer Z series Pyro/ boost, Diy Idm mod , shimed FPR, ccv mod, Diy Intake, 7.3 IC, Southbend Con o, 3" dp-4" Hog-6" Aussie stacks.
- 3" rsk, rear 2" add a leaf, 35" BFG all-terrains on 16x10 MT Classic II's, xrf ball joints and tie rods.
- line x'd rear bumper, clear headlights, turn signals, cab lights, 3rd brake and tail lights.
- Sittin in the garage, coolant filter kit, 203* stat.
- Next, Adrenaline, fuel syst. etc......
Pics.
http://entertainment.webshots.com/al...=entertainment
powerstrokin1997 is offline
Old 11-11-2009, 06:21 AM   #6 (permalink)
New bushings came all ready installed in the springs when they were ordered thru the ford dealer
dooboz is offline
Old 11-11-2009, 07:26 AM   #7 (permalink)
I would look into the TTB bushing at the crossmember. When they wear out it would allow the arm to move around which could allow it to have that lean.
CAI
IDM mod
TS 6 pos. Chip
3" PA Body lift
B&M deep pan
Adrenaline HPOP
Old 11-11-2009, 09:34 AM   #8 (permalink)
pjwoolw's Avatar
My Photos: (5)
The front spring hangers that attach to the frame and the spring are what you need to check.
This is what I'm speaking of.
Pete in San Ramon
pjwoolw is offline
