Fuel Additives - Diesel Forum - TheDieselStop.com
Old 11-03-2009, 08:28 PM   #1 (permalink)
Fuel Additives
I know they use methyl hydrate in gasoline to remove water.... I am using fuel conditioners, but what can you use to specifically remove water from diesel?
96 FORD SUPERCAB, 5"LIFT, 315 BFG M/T'S, 10 000LB WARN WINCH, BUSH BUMPER, GUTTED EBPV, K&n AIR INTAKE, OPEN EXHAUST AFTER DOWNPIPE, WAITIN FOR $$ FOR MORE MODS.
HELLRAISER is offline
Old 11-03-2009, 08:43 PM   #2 (permalink)
pjwoolw's Avatar
My Photos: (5)
Seafoam ought to take care of it.
Pete in San Ramon
2005 F250 6.0 Lariat 4X4 CC short bed (Stock)
1997 F250 7.3 XLT 4X4 Reg. cab (Stock)
1986 F250 6.9 XLT 4X4 Gone but not forgotten
pjwoolw is offline
Old 11-03-2009, 08:52 PM   #3 (permalink)
bugman's Avatar
My Photos: (18)
In reality I don't believe that an additive can remove water from diesel. In a gasoline engine the additive mixes with the water and then mixes with the gas in order to burn it. It never changes the chemical structure of water.
That is why in a diesel you will always find a water separator on the fuel system
I could be wrong but the above is what I have been told.
96 F250 PS XLT 4X4 long box, 5sp,4.10, manual hubs,pyro+boost guages,Dark Toumaline, add a leaf,Dale's TYMAR,and HX hose, downpipe, coolant filter
bugman is offline
Old 11-03-2009, 09:34 PM   #4 (permalink)
pjwoolw's Avatar
My Photos: (5)
Agreed. I would think if a problem were severe enough one would have to drop the tanks anyway.
Here is some interesting reading.
Pete in San Ramon
pjwoolw is offline
Old 11-03-2009, 11:17 PM   #5 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
Yes, you want to separate the water from the diesel (instead of mixing it). The water will mess up our injectors. You can use fuel additives to keep the fuel from gelling, add lubricity, etc, but don't get one that will mix the water and fuel (i.e., contains alcohol)! Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 11-04-2009, 02:07 AM   #6 (permalink)
FPPF makes an additive that actually separates the oxygen & hydrogen atoms. Unfortunately it only disperses the same volume. ie 1 oz FPPF disperses 1 oz H2O. Ok for condensation maybe. Best to use a water separator.
Evel486 is online now
Old 11-04-2009, 02:56 PM   #7 (permalink)
Thanks. I change my fuel filter on a regular basis and drain my fuel bowl, there is no issue with water per say.... but i am approaching 300000km on my injectors, and want to keep them running efficiently as long as possible. I just performed a BG fuel injection service on my truck, and I don't normally believe in the flushes and etc.... I am a firm believer in regular maintenance, and not messing with the hot oil flushes etc. However, I can say the truck idles and runs smoother with this service. I also have a customer who used the BG engine oil treatment and they were extremely impressed in the fuel economy and the power difference. They had 260 000km on it. Apparently it was noticable and cleaned the sludge out of the high pressure oil orphises in the fuel injectors. I have a free trial kit to try in mine. WAS very skeptical, but after seeing his, going to give it a try.... any one else have opinions on this?
Old 11-05-2009, 01:33 PM   #8 (permalink)
I would be interested in how your customer gained fuel mileage and power, any real numbers?
97 f250 4x4 ext cab tymar filter e4od 410 ts chip dp and 4" exhaust system
julyer is offline
Old 11-06-2009, 08:12 PM   #9 (permalink)
No solid numbers yet.... however he is recording fuel milage differences and taking an average based on several tanks to take as a comparison. I can't say the increase in power would be that noticable, however I can say the truck idles WAY smoother now. I will keep you posted with numbers. I don't suspect it will be significant, maybe 5% increase, but for the price of the service, I see value in it.
