Fuel bowl heater replacement - Diesel Forum - TheDieselStop.com
Old 11-21-2012, 03:13 PM   #1 (permalink)
So I keep blowing the 22 fuse for the fuel bowl heater, I am trying to disconnect the fuel bowl heater, but do not know how to remove it. The newer models look easy, but the old models I can't figure it out. Here is a link with both the old and new fuel filter heaters, I have the old one. Does anyone know the steps on taking this out without having the stand pipe fall apart?
http://www.superdutydiesel.com/wiki/...leId=11&page=2
Gioiapepsi is offline   Reply With Quote
Old 11-22-2012, 08:26 PM   #2 (permalink)
Unplug it from the out side of the bowl & replace the fuse ...
Rick.....
97 F 350 ...Lucky 13
"Most stuff's just stuck & needs hittin with a hammer .Supporter/End user of ShiftSolutions THE CURE E4/4R Trans Control. Helping Cancer patients and families
Special thanks to RacerX USA
action4478 is offline   Reply With Quote
Old 11-23-2012, 12:16 PM   #3 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
If you do want to remove/replace it:
Drain the fuel bowl and remove the filter.
Using a 7/8" crows-foot wrench, remove the standpipe (note that is LEFTHAND THREADED!)
Unplug the heater element at the small spade connector on the inside of the bowl and remove the heater (which includes the plate). Now is a good time to thoroughly clean out the bowl!
Replace the heater (if you are going to the trouble to do it, get the Dorman 904-210 SD-style element) by plugging it in first
Replace the standpipe, filter and lid.
Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, 3” DP, Bilsteins, $12 AIC, Coolant Filter, Explorer O/H Console, Trans Temp, Boost, and Pyro, Pedestal Mod, Gutted EBPV
Patrick Feeley is offline   Reply With Quote
Old 11-27-2012, 09:18 PM   #4 (permalink)
x2. Mine was unplugged for 7-8yrs before swapping to electric fuel. Started regularly at below zero temps and never had a gelling problem. Fired it up at -21 one morning last February.
Snowtow is offline   Reply With Quote
