fuel fill issue on front tank after RE/RE tank. - Diesel Forum - TheDieselStop.com
Old 07-04-2009, 09:00 PM   #1 (permalink)
S95
i recently had the front tank down for some work, upon reinstall and refill i now have a major issue on filling. it was ok before, what went wrong? i have checked and reinstalled the innner fill hose, and don't see any crushing or distortion of the outer vent hose. short of doing one of the mods, what could have changed??? as it filled quite well before. as far as i know there is just the outer fill hose as the vent on this tank.
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline
Old 07-04-2009, 11:59 PM   #2 (permalink)
Patrick Feeley's Avatar
My Photos: (19)
I've never had a tank out, but how about the rollover valve getting tweaked or plugged? (I really have no clue in this area ... just a shot in the dark). Cheers!
1997 F250 SC 4x4 (CA model), E4OD, 4.10 LS, Relocated Block Heater Plug, Mostly Stock
SOLD - 1994 F350 CC DRW 2WD, 5 Speed, SBC Con-O, Baldwin Filter, Tymar HPX Hose, DPPI DP, Bilsteins, $12 AIC, Coolant Filter, Explorer Overhead Console, A-Pillar w/ISSPRO Black Ice, EV Boost, and EV Pyro, Modified Pedestal, Gutted EBPV.
Patrick Feeley is offline
Old 07-05-2009, 09:53 AM   #3 (permalink)
I had the same problem on a F250 gasser that I dropped a tank on. I had to mess around with the fill tube and the inner tube on that before I finally got it right.
'94 F250xlt ext. cab. ZF5-speed 4x4. EBPV delete. DPP downpipe. Tymar intake. Tymar coolant filter. Type 31 batteries. LF9691 primary filter. Electric fans. 10k mod. 1.0 turbo housing. Boost blanket. Over-axle exhaust eliminated. Electric fuel pressure gauge. Heim joint clutch linkage. Adrenaline HPOP. BDP modded IDM. LUK SMFW. DIY Elec Fuel. FS1282, FF5320 fuel filters.
sdan27 is offline
