Fuel Filter Light - Diesel Forum - TheDieselStop.com
Old 11-26-2008, 09:18 PM   #1 (permalink)
Fireman87's Avatar
Fuel Filter Light
What warrants the fuel filter light to come on? I just replaced the filter about 3 weeks ago, i have never seen this light on before other than occationally when at WOT(rarely though), bad filter, dirty fuel?
shane
1997 F-250HD Reg. Cab 4X4 PSD "The Stroker", ZF5, 4.10, LUK Clutch Conversion, Coolant Filter, John Deere Coolant Eye, Custom Open Air Intake, 3" to 4" DP, 4" Straight Exhaust, Gutted EBPV, 4 Position Wildman Chip, Bully Dog Boost/Pyro, HPO Crossover Line, Amsoil Bypass Filter, All Amsoil Fluids, Cali. FPR, High Voltage IDM, Upgraded Headlight Harness, Scosche Remote Starter, Add-a-leafs in the front, One Ton springs in the rear, Owned Since 08/20/2004, 216K
2006 F-350 Reg. Cab Dually 4X4 PSD, Amsoil Fluids, 110K Owned Since 10/08/2011.
2003 International 4400 DT466 stock
1998 International 4900 DT466 stock
The Stroker
http://lubedealer.com/Lyttle/home.aspx
Independent AMSOIL Dealer
Fireman87 is offline
Old 11-26-2008, 09:34 PM   #2 (permalink)
I'll be watching this thread. I have an '03 and everytime we have a large swing in outside tempatures my light comes on. So I crawl under and drain the water seperator (sometimes it takes multipal drains) and light goes out. I had this happen when buying fuel at the same station or when on the road and very busy truck stops. I work with 3 other guys with the same truck (they don't add anything to their fuel) and they have never had their light to come on. I went back to the dealer and was told to put some water displacer in and keep draining. Well I do that but I just don't understand why my truck out of the 4 at work is the only one that seems to have this problem.
slides is offline
Old 11-26-2008, 09:48 PM   #3 (permalink)
S95
Fireman is talking about the fuel filter light.......it goes on when it senses a restriction (vacuum) in the fuel filter bowl. you have new filter so likely not that----(but could be?) Can be crud on one of the pick-ups if you have dual tanks or a venting problem, or? fuel pump dying?? either way you are using it faster than suppling it. switch tanks if you have duals and see if it is the same on both...
Slides........you seem to be talking about water in fuel....different light on our OBS trucks...and just what it says water!
1995 F-250 PSD 4X4 EXTRACAB LONG BOX AUTO
TYMAR FILTER, 4" MBRP STAINLESS TURBO TO TAIL
EOT MOD FOR COLD STARTS
CUSTOM RUNNING BOARDS
SD STARTER
STANDENS FULL 3 LEAF FRONT SPRINGS
1990 25th Anniversary 5.0 GT
S95 is offline
Old 11-26-2008, 09:59 PM   #4 (permalink)
chris u's Avatar
My 97 has the fuel filter light and also the water in fuel light.
97 F 250 4 inch lift with toyo LT 285/75/16 tires on ultra 16/ 10 wheels. Five speed manual transmission. Edge evolution programmer set on level 2 race. MBRP 4 inch turboback exhaust DYI 6637 intake and s&b cold air intake still trying to
decide what to use, ISSPRO pillar mounted gauges and a nice stereo system not going to list all that.
2007 chevy cobalt K&N cold air intake,Eibach prokit springs and 205 50 ZR 17 BFG g force sport tires on Konig wheels. With a sound system that will make you deaf.
2004 polaris sportsman 700 twin EFI with ITP 589 tires.
2001 honda cr 500 last year of the big 2 stroke.
98 polaris rmk 700 with big bore and way to much to list.
97 rmk trail 500 a little clutch work.
2005 ford focus ZX4 wifes car. Totaled 10/08
07 Mazda 6 wifes new car.
2000 F150 5.4 auto wifes truck
chris u is offline
Old 11-26-2008, 11:43 PM   #5 (permalink)
I have the same problem with the fuel filter light coming on, does it only when Iam using the front tank.
The research I have done seems to point to a restriction related to the front tank.
One of these days I plan on dropping the tank and having a look inside, until then I drained the front tank and only use the rear one.
1996 F250 XLT, Auto, 2WD, Extended Cab. Long Bed, 4.10 Gears.
Stock Except Tymar Intake.
Sticker Price $29,353.00.
Build Date 12/95.
60,000 miles.
obs96psd is offline
Old 11-27-2008, 10:18 AM   #6 (permalink)
MJLankford's Avatar
I just recently started to have that same problem. The front tank at about 40 mph shows the fuel filter light and if you drive 65 at 2000 rpm's the truck will shut off in like 8 - 10 minutes. I switched tanks and put some stanadyne performance formula in it and truck runs great.
Looks like I will eventually drop the front tank and see whats going on.
Matt
1996 F250 XLT, CC, SB, 4x4, 270,000 miles, 4.10 gears, E4OD, Tony Wildman 4 Pos. Chip, Shift Kit, Downpipe and 4" exhaust, 1997 F350 Dana 60 Axle swap with 3" RSK and 2004 F550 Superduty Springs "X codes", 16x8 Classic II and LT315/75R16 Nitto Terra Grapplers.
Truck Pics
MJLankford is offline
