Fuel Filter Restriction Sensor - Questions - Diesel Forum - TheDieselStop.com
post #1 of 14 (permalink) Old 01-18-2008, 01:34 PM Thread Starter
My Photos: (27)
Unhappy Fuel Filter Restriction Sensor - Questions
Hi all,
I recently developed a leak from this sensor and after reading some good information from past threads, I called up my local International dealer (in Denver) to check on availablity of this part.
#1809435c1
The parts person explained to me that it had been discontinued.
Has anyone else checked on this sensor and can confirm this?
Looks like I'll be getting the 1/8 NPT plug and some yellow teflon tape for my repair, rather than spending $$ at Ford.
Also, I was wondering if I was to get the sensor, is any yellow teflon tape required for it as well or just put the sensor in dry?
Thanks,
JB
PSD, TDE1, LWB, Auto, 4.10, 4x4, Manual Hubs, Overloads, White Century Topper
Mods:
, DPPI Downpipe, Bilsteins, Autometer Z-Series (Pyro, Tranny Temp, Boost) in Rockin S Pod, Tymar Intake and Coolant Filter, Tru-Cool Trans Cooler, Magnefine Trans Filter
TDS Mods: Gutterguarded Grill, <$10 Cold Air Intake, FPR Shimmed @ 70psi
JazzBass is offline
post #2 of 14 (permalink) Old 01-18-2008, 01:51 PM
I just bought sensor 1809435C1 earlier this week from an International dealer (Brattain in Portland, OR). My factory sensor was installed dry (no sealer). It did not appear to be leaking from the pipe thread (it was leaking through the body of the sensor). Be VERY careful threading the new one in. Mine goes into the fuel bowl itself (yours should go into the FPR), but both are known for being weak aluminum castings. My fuel bowl split with VERY little torque on the sensor.
Regards,
Michael Pliska
ISSPRO Engineering Manager
1995 F350 PSD Crew Cab Dually, 288k miles (Ford rebuilt E4OD at 226k)
10 ISSPRO Performax gauges, Tymar Intake, Gutted EBPV, Tymar 3x4" downpipe, Tymar 5" exhaust, Cat's hiding in the shed, Baby Swamps & Tunes, Tricumulator springs and Accumulator Valve, Tru-Cool 4590 Trans Cooler, Lock-Right Locker
2000 Jetta TDI - Kerma reflash, Der Chimera Stage II Clutch
1998 S&S 9.5' slide-in camper
33' enclosed tag trailer with 2 doorslammer drag cars (73 Vega Super-Gas & 74 Vega ET Super-Pro)
1992 GMC Typhoon, 1973 Chevy Blazer with Pontiac 400, 1973 Trans-Am 455
NRA member and certified firearms instructor
GOA member
IDPA member
MJPliska is offline
post #3 of 14 (permalink) Old 01-18-2008, 01:57 PM Thread Starter
My Photos: (27)
Thanks Michael,
Well, that's pretty odd. I may go down there in person and see what's up. I appreciate the words of caution as well. I have the same leak as well; from the sensor body.
If you don't mind my asking, how much did you pay for the sensor? (You can PM if you want or prefer)
Thanks,
JB
Mods:
JazzBass is offline
post #4 of 14 (permalink) Old 01-18-2008, 01:58 PM
hheynow's Avatar
Try powerstrokeshop.com for E8TZ-9S283-A. Many use the plug but I like to know while driving that there is a restriction. Don't use teflon tape in your fuel system. The smallest piece of tape can come loose and cause a clog. Use teflon paste or Permatex.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #5 of 14 (permalink) Old 01-18-2008, 02:28 PM
I have found that McCandless isn't very helpful over the phone. I needed quite a few parts awhile back and kept being told it didn't exist or discontinued. I went down with my list talked a bit with the Parts guy gave him my list and he pulled everything and gave a decent discount for my troubles... Since - I haven't called them, if I need something I simply go down there. But with the discount I can get from Ford, I don't hardly make the trip out there...
Sam
The Trash Truck
96 CC F350 SRW - Built for SVO and mileage
Go Green - HotFox, Dual Heated Dahl 100s, Fuel Filter Coolant Wrap, ArcticFox
Go Fast - Hybrids, H2E, 6.0 IC, Fuelab, BTS
thanx go to
Rockin-S-Performance - Install, tech support, and advice
Diesel Innovations - Killer Deal on Parts
Tony Wildman - Tuning
genie144 is offline
post #6 of 14 (permalink) Old 01-18-2008, 06:46 PM
BlueMule's Avatar
My Photos: (12)
You shouldn't use tape on it because it electrically isolates the sensor from the body and even if there is a restriction the circuit won't be completed and the light won't come on.
Rodney#33
BlueMule is offline
post #7 of 14 (permalink) Old 01-18-2008, 06:51 PM
Tom S's Avatar
My Photos: (20)
JB I have new one here that I do not need. Send me a PM.
Tom
96 F250SC 4X4 AUTO
F-6 live tuned, BTS Transmission, TN BB, Stage One Injectors, Custom electric fuel,
Banks Intercooler, Cowl Hood,
PMF RSK V and B code springs
Tom S is offline
post #8 of 14 (permalink) Old 01-20-2008, 02:34 PM Thread Starter
My Photos: (27)
Thanks to all
Hi all,
Thanks to everybody!
Well, it's nice to know (I guess ) that my experience is not the only one with the dealer.
Regarding the paste/tape - thanks for the info. I won't use any on the sensor, but I'm still unsure of (if I wind up getting a plug instead) which to use. I understand not wanting to get the tape in the system, but I had read some other negative stuff about the paste, so I don't know. I think a discussion of why one is better than the other would be beneficial for someone like me, who doesn't know.
I've PM'd Tom S and hopefully I'll have a sensor to replace.
Thanks again!
JB
Mods:
JazzBass is offline
post #9 of 14 (permalink) Old 01-20-2008, 03:03 PM
tape vs dope
I used yellow tape and a brass plug, and haven't had a problem since. To my thinking, tape is much more predictable in its final location than dope. If you go this route, use the smallest wrench you can, and your weak hand; try finger tight plus 1/4 turn, then start and check for leaks with a flashlight and your fingers. If you tighten too much you WILL crack the FPR and then either spend way too much at Ford or the next two evenings with spray solvent and JB Weld (don't ask.) I figure if you buy good fuel and check your filter from time to time, I don't need the FRS to tell me anything.
Josh
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter x3, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, newer black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, new fast-spool turbo 7/11, 317k miles on 18 Oct '14; probably won't run forever but neither will I
JoshR is offline
post #10 of 14 (permalink) Old 01-20-2008, 03:32 PM
Sorry, I didn't see the question about the price of the sensor. It was $31.82.
Regards,
Michael Pliska
GOA member
IDPA member
MJPliska is offline
post #11 of 14 (permalink) Old 02-25-2010, 07:52 AM
03hdfatboy's Avatar
My light just came on AFTER a filter change and I have no idea where the switch is.
1995 F250 Super Cab 4X4
03hdfatboy is offline
post #12 of 14 (permalink) Old 02-25-2010, 12:08 PM
fatboy here is a link to a picture of the sensor. Ford calls it a fuel filter vaccuum switch.
easy to take out, i did it yesterday in about 3 min. i didnt use any tape or paste though.
http://www.thedieselstop.com/forums/...tch-97fws1.gif
stock 1996 reg cab f250 7.3L automatic. 4x4.
arob_47 is offline
post #13 of 14 (permalink) Old 02-25-2010, 07:28 PM
Patrick Feeley's Avatar
My Photos: (19)
fatboy, it will depend on your truck. If you have an earlier 95 it could be on the backside of the fuel bowl, waaaay down towards the bottom (a real pain to change it even with a plug). If it is a later one, it should be on the regulator body on the driver's side (like in the picture posted by arob 47 ... much easier to get to). Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #14 of 14 (permalink) Old 02-26-2010, 09:01 AM
03hdfatboy's Avatar
Well after the post I took the cover off the top the the engine and found it and it must be an early 95 cause it looks like it is goin to be a PITA
thanks guys for the reply, It looks like I'll need a swivel or something.
Similar Threads
Fuel filter restriction sensor Fred Boden Power Strokes 1994-1997 General 4 11-25-2007 09:12 AM
Fuel filter restriction sensor leak need fix info Bret_B Power Strokes 1994-1997 General 5 11-21-2007 03:09 PM
Fuel Filter restriction sensor or ? highfive Power Strokes 1994-1997 General 2 11-01-2006 01:50 PM
Filter Restriction Sensor on 95 gooberdog Power Strokes 1994-1997 General 4 02-25-2006 12:02 AM
