Re: fuel gauge not working
mine just quit registering the front tank about 2 weeks ago. I havent had a chance to take apart the dash and make sure the switch is is seated to it's harness correctly, but that's where i'm going to start prior to dropping the tank and checking the sending unit. Is your intermitent tank working on the front, back, or dosent matter? If it works sometimes, but on both tanks, I would definately look into the switch in the dash. From what i've read in older threads, it seems to be a fairly common problem..
Joe
1997 F250 HD 7.3L PSD E40D 4X4 ; Dana 60 Conversion, 4" Superlift Suspension, ProComp ES9000 Shocks, Skyjacker Steering Stab.,Energy Suspension Poly Shackle & Track Bar Bushings, DIY Baldwin open element intake, 285/75 R16 Yokohama Geolanders,,15w40 Rotella T, Valvoline Maxlife Mercron ATF, Power Services Diesel Kleen (cetane +6), Midland 77-120 CB w/ Firestik FL2 4' Antenna. 1900RPM @ 70MPH. 197000 miles
Truck Birth-Month : October, 1997
TRUCK PICS
