hey guys my fuel heater has been disconnected for a while now and i have been considering running wmo or wvo so i want to replace the heater to help heat the fuel. i know the element is in fuel bowl but any hints on replaceing would be helpful thanks!!!!
ERIC 97 F-250 Red ext.cab long bed 4X4 junky slush box e4od 4.10 gears no muffler, new power steering pump, vaccum pump, fuel pump,water pump, fuel heater un plugged, k&n air filter, waste oil powered free fuel nothing like stickin it to the man217,000 still running strong 67 F-100 Ranger 351 W auto my first truck 93 mazda b2600i auto 143,000
wifes ride 98 lincoln navigator
Me thinks you shouldnt rely on the fuel bowl heater alone, considering all the fuel in the lines and tank.
Randy
Midnight black '94 * F-250 * 4x4 * ZF-5 * 3:55 * cc/lwb * RDS Single Shot Stage I's* TDP 6pos chip * BDP electric fuel * BDP D-66 Turbo * IDM Mod * Hypermax 3x4" dp * Authentic Tymar intake* 7.3 Intercooler * gutted ebpv * 4" exhaust & 5" tip * LUK clutch * A-pillar pod w/ Auto Meter NV boost, pyro and water temp gauges * reverse dash lighting and hvac controls * Optima yellow top batts D75/25, both on the right side * HPO X-over mod * manually controlled gp's * cruise control mod * add-a-leaf (front) * AC mod
I replaced mine twice, and the third time I just said heck with it and left it out of the circuit. Even in Colorado at 20 below zero no problems. I'm much more worried about that piece of crap shorting, blowing the fuse and sitting in the middle of 90mph interstate traffic with no start. Talk about a recall that should be done, could result in a very dangerous situation to say the least. In SC you don't need it. What it does, which I'm sure most know, but just to reinterate is heat the bowl to keep the filter from clogging with ice in extreme cold weather. It does no more, no less. If you don't have extreme cold and use fuel which is Winterized, which I believe all is in the Winter, the heater has no benefit. It's not like a thermostat that keeps the fuel at temperatures for improved performance ect. Engine doesn't know or care if fuel is 100 degrees or 10 below as long as it's not gelled.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
alright guys thanks for the help i will prob just forget about it. ive not had problem with it yet , other than being on side of road when it shorted out. i was just wondering it might would help with burnin waste oil or veggie oil.
2003 F350 crew cab 4x4 Bone Stock.
RIP, For now. Left in a field in Wyoming.
96 7.3 f250 4x4 ext cab , longbed,3" downpipe to a test pipe, Gutted ebpv, tw 4chip, stage 1 injectors,Stealth oil pump,Electric fans. shimmed fpr . 19 mpg in economy mode 8mpg in extreme mode. 281,117 miles as of 11-30-11.
get the newer one and from intertrashnal its is a lot cheaper
__________________ 1997 F 350 4X4, idm mod, wide open performance GQSSB turbo, stage 2` s by bean` s, intercooler, 4" no muffler, stack, trans from brians truck shop rear, disk brakes, and a stecher stage 1 hpop 6 position chip with bean` s programs crane valae springs, air dog lift pump and electric fuel pump and regulatorand water methonal injection
