Fuel heater, were to disconnect? - Diesel Forum - TheDieselStop.com
post #1 of 20 (permalink) Old 01-26-2009, 10:18 AM Thread Starter
Hey guys, My 95 died last week. Just got back in town and after looking at the truck Im wondering if I can unplug the heater outside the fuel bowl? The connect to the housing appears to be sealed?
Do you just un plug it in the bowl and remove the element? Does the wire just dangle in there?
It blew my 30 amp maxi. When I uplug the harness the fuse dosent blow and my WTS light works again. So I think its my fuel heater. And I just want to disconnect it. Not to cold in West Wash. and from what Ive read, its not really needed.
Good thing was it happened 20 feet away from my driveway!
Thanks in advance guys.
Bob D is offline
post #2 of 20 (permalink) Old 01-26-2009, 11:55 AM
ScottFraser2's Avatar
yeah you can unplug it from outside of the fuel bowl. Or, you can go inside the housing, remove the filter, remove the standpipe (left had thread) then unplug the heater and pull it out. There is a plastic connector that has a seal on it and its pushed into the fuel canister to seal the fuel from leaking out. It is much like our valve cover gaskets. You can unplug the heater from whatever side you feel like to.
1986 F-250 Supercab 2wd 6.9l T-19B 4 speed 200,000 kms (125000 miles) College teacher dropped it off at my house to have for FREE !
1990 F-350 XLT Lariat CC 4x4 SRW 7.3l, E4OD (Now ZF5 with Luk SMF), 3.55, 281000 kms (175000 miles) Paid $1300 01/05
1995 F-250 XL Supercab 4x4 7.3PSD ZF5 (Luk clutch/SMF) 3.55 265000 kms (164000 miles) Paid $6200 10/08
2005 E-150 XL 4.6l V8 60000 kms (37000 miles) Paid $15000 09/07
ScottFraser2 is offline
post #3 of 20 (permalink) Old 01-26-2009, 12:25 PM Thread Starter
Thanks, It seems like a turd to get the plastic seal out of the side of the housing. Especially since Im really not soure how it works. Ill probably just go in from the inside. Or I could remove the wire terminal from the connector I suppose too.
If you remove it from the inside, does the wire just hang there? Seems that could cause the same problem?
Bob D is offline
post #4 of 20 (permalink) Old 01-26-2009, 12:31 PM
bugman's Avatar
My Photos: (12)
It is a spade type connector on the outside and with the heat and age you may need a screwdriver to pop it off. As far as the inside if you go that route just unplug it. If you look at it on the inside of the bowl you will see that the heater element has three pads that it is connected to. Usually a couple of them break loose and then the heater flops around in the housing witch causes the short. You do not have to remove the heater element unless you plan on replacing it.
Jim
bugman is offline
post #5 of 20 (permalink) Old 01-26-2009, 12:33 PM
Just unplug it from the outside a single plug on drivers side. Leave it that way mine has been this way for 3 years and no problems. You get enough heat off engine to warm the fuel. just my .02
Jeep1947 is offline
post #6 of 20 (permalink) Old 01-26-2009, 12:58 PM Thread Starter
thanks guys. Ill give her a whirl tonight.
Bob D is offline
post #7 of 20 (permalink) Old 01-26-2009, 01:45 PM
It's a helluva lot easier to do from inside the canister...
'96 F350 XLT CC 4x4 PSD auto LWB 4.10 open, white, open intake, Tymar HX, 3"DPP downpipe, 315 General A/T on factory Alcoas, F add-a-leaf, new alt x3, fuel pump x3, water pump x2, vac pump x 3, PS pump x3, SD starter x3, rebuilt seats, total poly bushing kit, serious noise reduction, new tan interior and vinyl floor, Bilsteins, Bean's Stage 1s, Tony Wildman 4-pos chip (wow), etc ad infinitum, newer black Lab in backseat, locally rebuilt tranny & new TC @ 211k, complete body 'makeover' and repaint @ 213k, new fast-spool turbo 7/11, 317k miles on 18 Oct '14; probably won't run forever but neither will I
JoshR is offline
post #8 of 20 (permalink) Old 01-26-2009, 01:53 PM
Patrick Feeley's Avatar
My Photos: (19)
I've actually broken the "fuel heater thermostat" (the part that attaches to the fuel bowl) trying to get the spade connector off from the outside. That part is about $40-$45 from Ford and is sealed with an o-ring and a hold-down clamp. I always disconnect mine from the spade connector inside the bowl. If you do want to remove the element and it's already fubar, leave the plate in there as removing it may cause problems since the standpipe will sit slightly lower without it in there. Cheers!
97 F250 SC 4x4 (CA model), E4OD, 4.10 LS,
, Ext Trans Filter, Tru-Cool Max, I/C Mounted but not Plumbed
SOLD: 94 F350 CC DRW, 5 Speed, SBC Con-O,
, 3 DP, Bilsteins,
, Gutted EBPV
Patrick Feeley is offline
post #9 of 20 (permalink) Old 01-26-2009, 02:06 PM Thread Starter
I'll go from the inside. Still curious as to the wire though. Does it just hang in there once unplugged? What if it touches something?
Bob D is offline
post #10 of 20 (permalink) Old 01-26-2009, 02:13 PM
My Photos: (19)
The wire from the element won't hurt anything if it touches. It would only cause problems if it contacted the spade that it was disconnected from (if the heater is already messed up, you can disconnect it and clip the wire off ... or just rip the element off the plate). Cheers!
, 3 DP, Bilsteins,
, Gutted EBPV
post #11 of 20 (permalink) Old 01-26-2009, 02:22 PM Thread Starter
Got it. Thanks again, with 260,000 miles on this rig. I know about everything that can go wrong. This is a new one to me. But, like allot of the other problems, you guys have usaully talked about it. Great site and great info.
Bob D is offline
post #12 of 20 (permalink) Old 01-27-2009, 12:51 AM
Five years ago when this truck was new to me, I had the fuel heater element come loose and leave me dead at roadside a block from a buddy's house. I walked there, asked to use his computer, logged on here and asked for help. The first reply came 15 minutes later (from Jim in Alaska) who was dead-on with his diagnosis. I was able to disconnect the heater, replace the #22 maxifuse, and get home (then) to Chicago... I said it then, and I too will say it again: Gawd this is a great site, and thanks to all who pass on what they know...
Josh
JoshR is offline
post #13 of 20 (permalink) Old 01-27-2009, 09:11 AM Thread Starter
It was a success. The element was disconnected at all 3 solder joints from the plate. The terminal slid right off and out came the element. The terminal inside is right on the body of the bowl so no wire dangles and no chance of anything touching it. Plate is still in to keep the proper standpipe height. Did not even have to remove the pipe.
15 minutes from start to finish. Truck fired right up. Thanks everyone. Thank god this did not happen out on the Oly Penn. We were loaded with 4 pontoons and all our Steelhead gear. Could have been a 300 plus dollar tow bill. Plus the shop most likely would have been at least 200 if no reamage was used. Lol
It costs 8 bucks in fuses...
Bob D is offline
post #14 of 20 (permalink) Old 01-27-2009, 10:06 AM
I'm glad it worked out so well. I think I was among the first to have this happen way back about 10 yrs ago. Nobody knew the problem then, but it shorted right in my driveway thank the Lord. They recalled the trucks for the CPS. It seems to me this heater is even more of a danger. Leave it out of the circuit.
1997 F350CC, 4x4, PSD Tipper pro kleenex open filter. Roggen 6" lift kit with 26" ratflex 12" offset tires. Downpipe cut and welded to adapt 3" into a 12" outlet. 12" muffler cut and adapted to 2", then a special turbo manifold from a volkswagon modified to flank out to 3" to the tail pipe. Interior from a Corvair modified by cutting 6" off the padding. Snize and snide 32gallon aux tank mounted in rear seat, rear seat relocated to bed. Bed shortened to 4ft.
RonKZ650 is offline
post #15 of 20 (permalink) Old 02-12-2009, 05:09 PM
fuel heater element
My element has come dislodged at all three contacts as well. I was seeking out a reason for my truck having stalled and then refusing to start up. Filter is dirty as hell, and lots of gunk down there, but lo and behold, the damn heater is dangling all over. What i dont understand, is would this stop a moving truck. i would think a short would be significant, but only later, when trying to run a colder truck. this was warm as can be. i must be missing something vital here...
thank in advance,
sam
samduket is offline
