Fuel Pressure Help?
What should fuel pressure at the schrader valve on the filter housing be ? I know it should be between 40-60psi idling but what while it's under load driving it? Also I can Move the compressor wheel in my turbo up and down just a little it's enough that it will touch the housing, is a little play normal or is it time for a rebuild? Thanks fellars, Dave
Truck has 130,000 miles
1997 F250 HD 4x4 5speed Reg Cab, 4" MBRP exhaust, 1.0 turbo housing, Tymar Intake , 17* HPOP,Swamps 150cc, TW 4 position chip, Dana 60 w/RSK, Crossover steering, sittin on 35's
