fuel problems - Diesel Forum - TheDieselStop.com
Old 03-05-2005, 07:53 PM   #1 (permalink)
fuel problems
97 f250 psd with banks big hoss chip 3 inch turbine outlet pipe going to five inch stack . my truck seems to be suckin fuel i only get about 250 miles on a 19 gallon tank any thoughts on what it could be thanks [img]/ubbthreads/images/graemlins/confused.gif[/img]
IDRATHERBSTROKED is offline
Old 03-05-2005, 08:49 PM   #2 (permalink)
My Photos: (60)
Re: fuel problems
19 gal tank - do you run it all the way dry or to EMPTY on the gauge? If to EMPTY you may not be using all 19 gallons. Figuring 250 miles on 19 gallons of fuel is 13.16 MPG. When either of my tanks gets to EMPTY on the gauge I have three gallons of fuel left so if that is the case for you your 19 becomes 16 which figures to 15.63 MPG.
Also, you do not show the configuration of your truck - 2 or 4 wheel drive, manual or auto trans, standard size or oversize tires, lifted or not, differential ratios.
All will have an effect. If you are a conservative driver who stays under 2000 rpm most all the time in a two wheel drive truck with standard tires and a manual transmission that is low. If, on the other hand, you are running lifted with 38" tires (not corrected in the odometer/speedometer for tire size), run 75-80 on the interstate with 4.10 gears and enjoy using the power of the chip while smoking the ricer next to you (I know, stacks don't go into the window - the only disadvantage to them) then you are actually doing pretty well.
Dave / Believer45
THANK YOU to all the heroes in our military and all the heroes at home who wait for their safe return. I am humbled by and grateful for your service and sacrifice.
LINK TO LIST OF THE FALLEN
'95 F250 ext cab long bed, PSD, 5 speed, 2 wheel drive, 3.55 gears, 286,000 miles, Edge Evolution CTS (LINK TO MY REVIEW), LUK clutch, homemade REAR BUMPER, open element AIR FILTER, 36" ARE contractor cap. With tools, full of fuel and me on board (300 lbs) steer 3620, drive 3860 total 7480.
Believer45 is offline
Old 03-05-2005, 09:15 PM   #3 (permalink)
Re: fuel problems
I Dunno! I used to get 250 miles per tank consistantly. Now only 200 or so [img]/ubbthreads/images/graemlins/confused.gif[/img]. I guess these trucks are like us old guy's. They'er get'in older, worked too hard and eat more? [img]/ubbthreads/images/graemlins/shrug.gif[/img]
1997 F-350 Powerstroke Crew Cab 5-SPEED SRW 4x4
Lund Visor, Velvac Stainless Steel Mirrors, Ford AIC
1976 Jeep CJ-7
totljeep is offline
