fuel pump help - Diesel Forum - TheDieselStop.com
Old 12-05-2012, 04:09 PM   #1 (permalink)
fuel pump help
1997 f350 two wheel drive 7.3 powerstroke what is the best and easiest way to change fuel pump. should i go electric?
jacksnicky is offline   Reply With Quote
Old 12-05-2012, 05:31 PM   #2 (permalink)
Remove fuel bowl, y-pipe, then pump. After you've done it the first time, it can be done fairly fast. You need an inch and a quarter wrench I believe. Just do a search and you will find some more detailed instructions. I'm not knowledgeable with the e-fuel.
1995 F350 XLT Powerstroke Turbo Diesel 7.3l 2wd Crew Cab Automatic. 275,000 miles and counting.
Bilstein Shocks, Aftermarket Downpipe, High Pressure Crossover Hose, Viper alarm and remote start, Tranny cooler, Cat delete, Homemade open air intake, Dick Cepek cab lights, Glow Plug Relay Mod, IDM Mod, A/C Mod, Dual Electric Fans, PHP 6-Position Chip.
jtbel is offline   Reply With Quote
Old 12-05-2012, 05:41 PM   #3 (permalink)
bugman's Avatar
My Photos: (12)
Follow this LINK to a thread that has Sam Millers fuel pump procedure in it.
A couple of things that I would add to it is that when the pump is loose turn the engine over by hand and let the cam and tappet raise the pump up off of the engine. That way you will not loose the tappet down into the oil pan. Also replace both of the copper washers on the banjo bolt and all the hoses from the filter housing.
bugman is online now   Reply With Quote
