Fuel Pump Replacement Labor - Diesel Forum - TheDieselStop.com
post #1 of 11 (permalink) Old 02-13-2008, 07:45 AM Thread Starter
My local dealer is charging me 3 hrs labor to replace the fuel pump. Seems reasonable to me, what do you think?
96 F250 XLT 7.3 Powerstroke Turbo Diesel 4x4
sixgun95 is offline
post #2 of 11 (permalink) Old 02-13-2008, 07:47 AM
MarkEkberg's Avatar
My Photos: (13)
More like two for someone who knows how to do it. Heck if they are good they could do it in a hour I would think.
Your looking at a total of around $450 for the job? Not crazy, but not great either.
UPDATED 1/1/09 Replace so far. 1 LUK flywheel+clutch, 2 thermostats, 2 set of brakes, 1 set of calipers, 5 CPS, 3 sets of tires, 2 Transfer pumps, 1 Injector modual, 1 Computer, 2 Alt, 2 sets of batteries, 1 Water pump, 6 Belts, 1 PS hose, 2 Sets ball joints, 2 set u-joints, 2 carrier bearing, 2 Speed sensors, 1 oil pres sender, 1 temp sender, 4 sets of e-break cables, 1 front fuel tank, 2 rear fuel tanks, 2 set of glow plugs, 7 Glow plug relays, Oil galley o-rings, Turbo pedistal o-rings, EBPV o-rings, 3 sets of Injector O-rings, 1 Vac-pump, 1 new carpet, 1 total paint job.Total $$$ in repairs v/s miles driven = 4.6 cents per mile. Add fuel to that it jumps to 16.5 cents per mile over the life of the truck.
MarkEkberg is offline
post #3 of 11 (permalink) Old 02-13-2008, 07:48 AM
Cratos's Avatar
My Photos: (15)
3 hrs at what rate ? if you have time it.s not to bad a job .just restarting the bango bolt is a pita.
2012 XLT SCLB 4X4, FX4 SCLB Camper & Tow package, Dark Pearl Blue. Airlift bags and Wireless Air controller
Cratos is offline
post #4 of 11 (permalink) Old 02-13-2008, 07:55 AM Thread Starter
Price, just for labor is $250.
sixgun95 is offline
post #5 of 11 (permalink) Old 02-13-2008, 11:13 AM
AaronKuorikoski's Avatar
Take it. If I had to do it again right now, I wouldn't take a penny less than $400.
Aaron
1995 F-250 XLT PSD 4WD, SC, 7.3 Turbo, LB, 3:55, 5-speed, 228k miles.
Mods: Aluminum diamond plate step and side rails, 4 foot CB antennas with Cobra 29 NW LTD Classic, Duplicolor Spray-on Bed Liner, DIY Tymar intake, Kelly-Springfield Trailmark MS Radials 285/75/16, CAT ELC Coolant, Clutch lever-Ebay mod, Delta deep gull-wing aluminum truck box, Bilstein Heavy Duty shocks - on their way!
AaronKuorikoski is offline
post #6 of 11 (permalink) Old 02-13-2008, 11:19 AM
It's rare for the actual time to ever take as long as book time says it will on any repair.
Snowtow is offline
post #7 of 11 (permalink) Old 02-13-2008, 01:03 PM
thats a fair price IMO
1997 PSD #34 Beans electric fuel, H2E FFD 230cc stroked acodes TWildman 6 position Tymar intake, 17*hpop, IDM mod, diamond back 4" turbo back dual exhaust (SD DP), Arp studs, comp valvesprings, 7.3 intercooler, Rough Country 4" lift, 315 Cepeks FC 2 on MT classics, Bdog electrolum gauges (pre/post turbo pyro), E4OD auto, 4.10LS, TC LU w/ ind light, CCV mod, Richter69 TC and accum body, 203* tstat, clear turn signals, toolbox light, ford manual hub conv., ext trim gone.
Highest hp 498, highest tq 950 corrected
Work truck: 03 7.3 excab lb F250
New Family rig: 2002 7.3 Excursion edge evo II, mbrp 4" tb exhaust, tymar intake
Big_Dan97 is offline
post #8 of 11 (permalink) Old 02-13-2008, 01:14 PM
I Admit They Are A Pain To Replace. My Local Ky Ford Dealer Quoted Me 3hrs Labor At $70. Per Hr.
camsales is offline
post #9 of 11 (permalink) Old 02-13-2008, 02:21 PM
PSDfreak's Avatar
I agree, not a bad price...Jobs not hard, just a PITA and way to cramp up your back for an afternoon...If you have IC piping, add some time in there to R&R that too.
●4x4●ZF-5●4.10●Tymar Intake●Wildman 6 Pos. Chip●SD Intercooler●17* HPOP●4 Straight Pipe w/5 Silverline Tip●3-Pillar Zeries Gauges (Pyro/Boost/Oil Temp)●3.5" RSK/D60/SD Springs●Ride Rite Rear Bags●Bilstein 5100 Shocks●315/75/R16 BFG A/T●Pro Comp XTreme Wheels --- SOLD 01/2011
2009 F-250 FX4 - Diesel - Crew Cab/Long Bed - 4" Pure Performance X-Factor Lift - 325/60/20 Goodyear Duratracs on Stock 20's
PSDfreak is offline
post #10 of 11 (permalink) Old 02-13-2008, 07:39 PM
hheynow's Avatar
That a fair price because the book says 5.1 hours based on needing to remove the turbo, but as we all know that's not necessary.
'97 F-350 7.3L PSD RC LB 4WD E4OD - Plant Drive VO kit
'84 Mercedes Euro 300D NA - Custom two-tank VO
Running on Veg Oil and Biodiesel since May 2006
hheynow is offline
post #11 of 11 (permalink) Old 02-16-2008, 12:21 PM
That sounds pretty reasonable. Local dealer here qouted me 1500 for parts & labor. so mines going to be a DIY
'97 F250 4X4 Super Cab long bed XLT, PSD, K&N air Filter, Bilstien shocks, diamond plate rail caps, Flip-Pack camper shell, cracked windshield, coffee stain in headliner, now missing both $#@! rear center caps.
Truckaholic is offline
