Fuel pump safety switch - Diesel Forum - TheDieselStop.com
Old 05-23-2005, 11:46 PM   #1 (permalink)
Does the PSD have a fuel pump safety switch like the gas model truck?
I just got finished installing a LUK flywheel/downpipe combination on a friend's 96 CC. Lots of floorpan massaging to clear the pipe. You know, Sawsall and hammer.
The thing is, the truck won't start now for nothing!
Could I have tripped the switch by beating on the floor?
Owner's manual says it's behind the RH kick panel, which it ain't. I guess that is just for gassers, right?
Help is appreciated. Gotta drive this thing to marvel in the improvement.
Thanks,
Barry
94.5 F350 Supercab 2WD Dually. 5 speed PSD and 250,000 mi. Hypermax DP, LUK SMFW and no cat.
Oldngiveout is offline
Old 05-23-2005, 11:50 PM   #2 (permalink)
Re: Fuel pump safety switch
The diesels do not have the fuel pump shut off. I don't know what to tell you about the no-start.
Tim
"Better to be hated for who you are, than loved for who you're not." - Van Zant
My Truck 1972 F-350 4x4 Extended cab 14-36 Swampers, 97 Powerstroke, 4 position chip with custom tunes, 3" downpipe, 5" exhaust, 99 intercooler, DIY E-fuel, Dana 60 front, 70 rear, lockers in both ends.
<font color="blue">72 POWER STROKE</font> <font color="red"> INTERIOR PICTURE </font> <font color="blue"> ENGINE PICTURE </font>
Wifes' Grocery Getter 99 F-250 SD 4x4 XLT Lariat 4 door. 7.3, Auto, 4 pos Bullydog chip, 3 1/2" downpipe, 5" straightpipe, Genuine Tymar, Stage 1 Monsterbox, 33-12.50-16.5's
72Pstroke is offline
Old 05-23-2005, 11:50 PM   #3 (permalink)
I have not heard of a kill switch in these trucks, nor have i seen one.
96' F350 4X4. E4OD tranny running Amsoil synthetic, 1 big tranny cooler and tricumulator springs and accumulator valve. Autometer guages, homemade intake, TS 6 position Chip (tuning by Diesel Innovations , Factory AIC, A/C mod, MBRP 4" Exaust, BDP Stage I injectors, Brakesmart trailer brake controller, T/C lockup switch
Soon to be installed: Innercooler (sittin at the shop), Big Oil, Built Tranny, Coolant Filter, HX hose, and some others. 350k miles.
Truck pics
Houston Area Powerstrokes
TimMiller is offline
Old 05-23-2005, 11:52 PM   #4 (permalink)
Should be a mechanical pump if still stock, so no switch. Not sure what you might have bumped, but check all wiring at the starter and on top of the engine. Also check for blown fuses under hood and in cab.
JOAT is offline
Old 05-24-2005, 12:32 AM   #5 (permalink)
Hey, great news! I let the battery charger replenish the batteries for about an hour, and low and behold it finally choked to life.
I don't understand. With my experience, these trucks don't like the batteries being disconnected for a day or so. I know the PCM had to relearn the driving portion, but I couldn't even get it to start so that I could.
Apparently you were right, there is no fuel cutoff switch.
Thanks for the quick replies.
Old 05-24-2005, 01:16 PM   #6 (permalink)
Have the batteries load tested. If they get weak it may crank OK but not leave enough voltage for the IDM to fire.
JOAT is offline
Old 05-24-2005, 04:11 PM   #7 (permalink)
Just for an FYI, always check to see the the tach moves while cranking. If it doesn't it means the CPS (crankshaft position sensor it bad). When they go bad they won't start if your life depended on it.
Truck pics
